P700 Interforce ag tires
motorman18
439
277
Laurel, MS
Is anyone running interforce tires on a p700 im wantin to run 30s scared won't pull
I haven't seen anyone try it yet. Depending on lift and wheel off-set, they may not fit. I had true 28" tires and they rubbed.
The after market is catching up now though. It looks like you can get portal boxes for lift and lower gearing now. Also, you can get arched a-arms so you can do it depending how committed you are.
I would try the 30x8 first. At least use those for the front.
Reactions: CumminsPusher
motorman18
439
277
Laurel, MS
Yeah i am in process of putting arched a arms on now thing with portals is the price if there was just a gear reduction like ring and pinion or the tranny gears wouldn't be so bad
You are correct, the price is steep. I myself have never bought any. However, you are getting a lift kit, wider stance, gear reduction for one price.
Keep us updated with some pictures of your build, It will be cool to see.
