Wouldn't it be easier to just take the blade off?Second cut of yr, same yard but found this , now this side cuts @ 1-2View attachment 327833View attachment 327834View attachment 327835View attachment 327836" lower
That's why I don't sharpen blades until after second mowing.Second cut of yr, same yard but found this , now this side cuts @ 1-2View attachment 327833View attachment 327834View attachment 327835View attachment 327836" lower
Exactly!same. all the pine cones, twigs and sweetgum balls get chopped up in the first mowing.
and chainssame. all the pine cones, twigs and sweetgum balls get chopped up in the first mowing.
mmm maybe, this way took @30 mins, master key to cut a few links to remove chain. Most time spent on floor jack and jack stands. Hoping it is just bent blade, just got out of services last week or soWouldn't it be easier to just take the blade off?
🤦♂️........what is it with people in GA and crocs???Second cut of yr, same yard but found this , now this side cuts @ 1-2View attachment 327833View attachment 327834View attachment 327835View attachment 327836" lower
Maybe it was the chain whipping the ground. I bought a spare set of blades for mine and keep them sharpened and just change them every time I service the engine, every 50 hours. If you had a spare blade you could lay the suspected bent blade on top of it and compare.mmm maybe, this way took @30 mins, master key to cut a few links to remove chain. Most time spent on floor jack and jack stands. Hoping it is just bent blade, just got out of services last week or so
I hear that trend is moving down to Florida!🤦♂️........what is it with people in GA and crocs???
@Backwoods!!!!😂😂😂
Croc alert 🤣🤣🤣🤣🤣🤣🤣🤣Second cut of yr, same yard but found this , now this side cuts @ 1-2View attachment 327833View attachment 327834View attachment 327835View attachment 327836" lower
Him and BW probably know each other very well🤣🤣🤣🤣🤣🤣🤣🤦♂️........what is it with people in GA and crocs???
@Backwoods!!!!😂😂😂
Another way to tell if the blade is bent without removing it would be to turn the mower off, safety 101 for liberals, then rotate the blade till the tip meets the adjoining blade and see how close they are vertically.
That sounds great, but I don't change mowers but about every 12-13 years.I've got this handy dandy John Deer blade measurement tool to adjust mowing heights for different mowers that you want to cut the same height. It was cheap, works great.
