is yours sharp?
waynester
waynester
254
1,250
Ga, USA
Its that time of year, touch up your mower blades for a clean cut, 20220324 182952 resized
906UP
906UP
13,040
121,605
da Yoop
I've still got the snowblower on my Lil'bota, we've got a month & half or 2 before we need the mower
toddvdh
toddvdh
1,066
7,001
Green Bay, WI
I put my plow away. Standard rule around here after St Pattie’s day. If the good lord gives snow, he can take it away.
Reactions: J80 and Buggyman
JenElio
JenElio
64,515
604,613
Loxahatchee, florida
Mopower58
Mopower58
CST is the Best!
70,318
645,529
Crystal Springs,Ms.
mmm maybe, this way took @30 mins, master key to cut a few links to remove chain. Most time spent on floor jack and jack stands. Hoping it is just bent blade, just got out of services last week or so
Maybe it was the chain whipping the ground. I bought a spare set of blades for mine and keep them sharpened and just change them every time I service the engine, every 50 hours. If you had a spare blade you could lay the suspected bent blade on top of it and compare.
Mopower58
Mopower58
CST is the Best!
70,318
645,529
Crystal Springs,Ms.
Another way to tell if the blade is bent without removing it would be to turn the mower off, safety 101 for liberals, then rotate the blade till the tip meets the adjoining blade and see how close they are vertically.
208,013
I've got this handy dandy John Deer blade measurement tool to adjust mowing heights for different mowers that you want to cut the same height. It was cheap, works great.
