Joining
32690taylor
32690taylor
NY
Hello, I'm 32690taylor
Just joined this site. Bought my P1K EPS back in May. Really pleased with it so far. Load it right up with firewood or anything else or anything else and it doesn't struggle at all. Been doing some upgrades a little bit at a time. Had the roof and winch installed at the dealer. So far I've put on a LED light bar, LED reverse/work lights, amber hazard light on the roof, horn, HighLifter 2.5 inch signature lift kit, and the limited front bumper. Hoping to upgrade tires to 28 inch Roctanes on red 14 inch STI HD7 wheels. I also have a YouTube channel with some short videos about my Pioneer, if your interested just search : Big Kid Cruisin' or you can click <Big Kid Cruisin'>.
Here is a little info about me to begin with!
Honda SxS ownership : Yes, this is my first.
I have owned, or currently own the following: UTV, ATV, Motorcycle
My off-road experience level is: Intermediate
My favorite place to ride is: Around the farm
IMG 20171107 190106266 IMG 20170905 183847590 IMG 20170803 170419245
Koda
Koda
565
2,309
Canton Ga
Welcome from North Georgia
Mudwing
Mudwing
36,959
306,672
The Mud holes
Welcome from Western New York! Good looking machine!
Welcome to the forum. Just a little heads up about your lift kit and tires selection, you will probably need to forward arched a arms to clear those 28 inch Roctane tires.
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Welcome aboard from SE Missouri
32690taylor
32690taylor
NY
Yeah, I was originally going to try 30" tires, but I know they won't fit without the forward A-arms. Been taking some measurements and 28" tires would fit with no trouble since they're only a couple inches bigger than stock. Also considering a set of 1" - 1 1/2" wheel spacers.
Tramguage1
Tramguage1
Texan
7,496
30,713
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Yeah, I was originally going to try 30" tires, but I know they won't fit without the forward A-arms. Been taking some measurements and 28" tires would fit with no trouble since they're only a in bigger than stock. Also considering a set of 1" - 1 1/2" wheel spacers.
I’ll ask some guys to chime in. The Roctanes are a lot more than one inch bigger than stock. Stock tires are actually 25.75-26” and the Roctanes are slightly more than 28 and wider. I can’t remember exactly but the guys that I will tag below had some rubbing using 28 inch Roctanes and the HL lift. It could be that it was rubbing the aftermarket skid plate but that’s still info you’d probably like to know. Just trying to help you out
@JACKAL
@Windrock1000
swsebek
swsebek
2,854
5,835
pa
Welcome from pa
32690taylor
32690taylor
NY
Thanks for that.
Windrock1000
Windrock1000
2,539
9,664
Windrock, Tennessee
F0220C6A 303F 41EF 8A4C 37196147E021
D51BAF87 8E3B 4DD4 B9AC 192A529E4500
1948E70D 4EFC 4ECD B74F 075552F699C9
049F0E8E 12EF 406F 8440 F0AF78BCDF1C
I’ve got your answer on 28” Roctanes and STI wheels. First off Roctanes measure 28.25” at 13 psi and sti wheel are 5+2 offset. Secondly you will have to trim aftermarket skidplates if you have them. Third the tires will rub on the drivers side inner fender. I ran 28” Roctanes on Sti5s for a few months before I added Superatv forward A-arms. No rubbing with the a-arms. I am running 1” spacers on the front and 2” spacers on the rear to balance out the width on the change in wheels. To do it over again- start with the forward front a-arms. Check out my build and it describes all the different combinations I’ve tried. By the way these are for sale as I moved up to 30’s.
P1000m5 - Windrock1000 is Finally Running on 30’s
322,675
E
elkguide
3,377
7,964
Vermont
Welcome aboard.
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Welcome from ND!
