June ROTM Submissions closed.
Status
Not open for further replies.
67,224
This Month there is a theme Requirement
Theme = Simple Ingenious (not for sale) Modifications!
We want to see your ingenious modifications and/or cleaver accessories that can not be bought. We are not looking for the biggest baddest custom mod. More like the simple mod that makes everyone say.... Why didn't I think of that!
  • Something you didn't buy.
  • Or.. Bought, but drastically modified.
  • Something custom you made.
  • Something custom you did.
ENTRY
Entry is simple, just post a picture in this thread to make your submission.
Describe the accessories and any info you would like to provide.
You may post up to 3 pictures if you like.
Posting your picture in this thread enters you into the contest.
71wF7YFy8UL SL1500
THE PRIZE -
This months we are giving away...
Pelican 2360 LED Tactical Light, Black
Product Description
If you like the convenience of AA alkaline batteries, but need the performance of lithium batteries, the new 2360 LED is the light for you. Using 2 standard AA alkaline batteries, the new 2360 LED emits a peak output of 95 lumens with a run time of up to 2 hours. Because when you are on the job, the last thing you need to worry about is a dim flashlight or dead batteries. Constructed with the most durable of materials: an aerospace grade aluminum body and an impact resistant LED lamp module, the 2360 LED keeps you on point without equipment failure. The non-slip textured body and push button tail switch are easy to operate in slippery conditions. The removable two way pocket clip securely attaches the 2360 to your pocket or the brim of your hat.
Designed for use on work sites, the 2360 LED Flashlight from Pelican offers the convenience of readily available AA alkaline batteries with a higher light performance--similar to what you would expect from costly lithium batteries. Using two standard AA alkaline batteries, the 2360 LED emits a peak output of 95 lumens with a run time of up to two hours. Constructed to last out of aerospace grade aluminum with an impact resistant LED lamp module, the 2360 is intended for use in demanding environments. The non-slip textured body offers a secure hold and the push button tail switch is easy to operate in slippery or wet conditions. The removable two-way pocket clip securely attaches the 2360 to your pocket or the brim of your hat.
Features:
  • Aerospace grade aluminum body
  • Impact resistant LED lamp module
  • Non-slip textured body
  • Push button tail switch
  • Removable two way pocket clip
Specifications:
  • Light Source: LED
  • Light Output (FL1 Standard): 94 Lumens
  • Runtime: 2 hours, 15 minutes
  • Beam Distance: 139 meters
  • Peak Beam Distance: 4893 candelas
  • Voltage: 3
  • Batteries: Two AA Alkaline (Not Included)
  • Length: 6.1 inches
  • Weight: 4.6 ounces with batteries; 2.9 ounces without batteries
TIMELINE -
Submission must be made by June 29th by 9pm EST.
Once submission is closed we will narrow the field down to the top 10.
Shortly after voting will begin. Voting will last around 7 days. Highest vote counts wins.
GOOD LUCK!
**** UPDATED RULES ****
Full rules here --> //hondasxs.com/threads/rules-rotm-ride-of-the-month-updated.828/
***** Sponsors Wanted *****
If you are in need of product marketing and interested in sponsoring a ROTM we would like to discuss it with you.
bobbyhill
bobbyhill
Junior Moderator
1,271
953
Smithfield, VA
June1 June3 June2
I took a float off an old rusted out anchor that I found out in the woods. The float is for fishing nets. I took a hack saw blade and my pocket knife and cut an 180deg spiral (or S pattern) and feed the cable thru and then pulled it tight so that the float cannot come off the cable. This will keep the hook from sucking up too tight and it will float the end of my hook so that it will not get snagged on anything under the water. So Duel proposes and on average it only saved me around $20 bucks. But ADDED 100% Character!!! I also added the HONDASXS.COM Sticker above winch hook so people would know who was helping them out!
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
Very clever! Plus if you're stuck in water and you drop your cable while spooling it out you don't lose it
67,224
That's a clever idea. I hate it when I drop the hook and have to search around in the mud.
bagotaco
bagotaco
121
77
20150607 185405 built a bed extender out of a safari roof rack for a jeep Cherokee. It was off a whole sell vehicle at work. Freebie
bobbyhill
bobbyhill
Junior Moderator
1,271
953
Smithfield, VA
@bagotaco Good Idea! Any chance I could get you to send the other half of that basket my way?;)
67,224
@bagotaco, you did a great job repurposing that rack. It looks like it's custom made from the picture. Thanks.
bagotaco
bagotaco
121
77
Sorry buddy I had to use both front and back for the double height lol
Chooglin
Made my own bumper out of 1 1/4" tubing . I plan on changing the color to green (not liking the white).
I have roughly 12 hrs in it and $35 .........a lot cheaper then the oem and I think it looks better !!!
EDIT: repainted Satin Black
bobbyhill
bobbyhill
Junior Moderator
1,271
953
Smithfield, VA
IT was worth a shot! lol
@Chooglin I was hoping you would post!
Reactions: Chooglin
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
Definitely cant buy this bed
Reactions: Hondasxs
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
Sry guys still haven't had time to finish the spare tire swing gate but i promise i will
Code54
Code54
585
635
Hurricane West Virginia
I feel the master cylinder on the P500 is not very well protected and I personally consider it rather important so I made a guard from my old skid plate and a scrap piece of metal. I put new HD skids on the 500 so I had the originals just sitting so I figured this would be a easy, quick project that may save me some money in the future.
Master cyl guard
Here it is before a guard was added
No guard
Here is something I did a while back to keep be branches from knocking my GoPro camera off target. It's a very durable cord like paracord or something, I can't remember. It's tied to the front brush guard and then tied to the ROPS. It makes the limbs climb up and over the roof which keeps them off the GoPro, off the mirrors, and out of my face. Best of all, it's super cheap.
Joey
67,224
Few more days left... if you have a custom made MOD post and tell us about it.
Status
