P1000m5 Just Pick My Tires for Me...
ehart814
ehart814
1,654
3,643
NWPA
Had an insane rain storm on Saturday night. Flooding everywhere. But Sunday it got into the mid 70's so we had to go for a ride.
Well, I found some serious mud. Was riding with 2 of my cousins and they were on 450 Foreman quads. Definitely put the tires to the test! Went down a long gas line and it was really soft. Water and mud the whole way. I ran in 4wd low the whole time. Couple small creek crossings that were washed out bad. My tires were sinking in that mud at least 5" or 6" the whole way. And the pace was pretty slow. I never had to really put my foot into it. The truck tires exceeded my expectations in conditions like that. They seem like they are always spinning, just slightly. But I never got stopped. I was nervous because I was really expecting to get stuck, but it just kept moving. It was a fun ride, but it seriously needs a bath now.
I'm happy, because I usually avoid mud as much as I can. But now I know I won't be totally handicapped if I can't avoid it.
Reactions: Napaul
Mopower58
Mopower58
No reservations about no reservations
69,510
639,691
Crystal Springs,Ms.
Check load capacity on any choices,that narrows it down.
I just ordered new set of maxxis bighorn 2.0 upgraded to 28 inch for my 1000-5 deluxe with 14" wheels.
My bighorn have never failed me in over 5500 miles.fronts showing wear,rears not bad.
I do run a lot in turf mode when on pavement to cut down on scrapping,firm believer this helps
That is what I put on mine.
IMG 0212
Napaul
Napaul
56
112
Did you lower the pressure before this? Still no bead problems I assume? We had some decent rain here Thursday night and the wife and kids and I spent the whole weekend riding. Great way to quarantine and enjoy the nice weather!
ehart814
ehart814
1,654
3,643
NWPA
Running 13 psi. Probably could lower it a bit more but the ride really isn't too bad. Had zero tire issues. We had a good time. Was a little nervous in the mud cuz we would have had a heck of a time if I'd gotten stuck. Two quads with nearly bald tires sitting in mud trying to pull a heavy Pioneer 1000 would be interesting.
Reactions: Napaul
Mopower58
Mopower58
69,510
639,691
Crystal Springs,Ms.
Not sure about the BH's but mine had the 12 inch wheels and tires and they are about 1 1/2 inches taller at 15 psi.
Reactions: helimech
helimech
helimech
110
190
that thing looks amazing Mopower58
Reactions: Mopower58
Smoke
Smoke
12
32
Indiana
I have 28 sti x comps and love them, they are good on pavement and a little mud, handle better and drive like a car right out of the showroom, they are heavy but I don't notice much power loss but seems to shift a little smoother
Napaul
Napaul
56
112
I really do like the X Comps. They should be super tough and smooth for sure. If I remember right I read where they were designed for the “high hp” machines that wouldn’t notice a heavier tire as much. I think they are the heaviest tire I have considered at almost 42 lbs each in the 28. I really didn’t want to go over 40 lbs per tire and was leaning more toward something in the 35-37 lbs range, but hearing good things about a tire, even a heavy one, is always good. I am willing to sacrifice a little power for a reliable and capable tire, but I worry about wear on the drivetrain as well. How long have you been running the X Comps?
Smoke
Smoke
12
32
Indiana
I've been running them for about 6 months, I ride alot of pavement where I live so far they are showing good wear, they are heavy I only notice a little power loss in situations where I gotta slowly crawl over a log or something like that but put it in 4wd and it's not as noticeable
Reactions: Napaul
Napaul
Napaul
56
112
That’s good to know. There’s a lot of land we have access to up and down the road so I run a lot of pavement just traveling back and forth. One of my biggest concerns is how a tire will hold up on asphalt.
Smoke
Smoke
12
32
Indiana
I had 900 mile on the stock front tires and they were smoked on pavement, so bad it would walk all over the road and just bounce..... so far I'm a little over 600 on these and they show little wear and for me it's perfect for summer rides and being in the woods for deer season or hauling in wood......I'm running 15 psi no bead lock wheels may try to run 10 and see what happens I'm most likely going back to the same tire the next go round as of right now, where are you from?
Reactions: Napaul
ToddACimer
ToddACimer
Pioneer 1005-2
3,549
14,537
Oshkosh, Wi
I keep looking at 30" tires. I really like my Quadboss 28x10s but I think 30s would look good and give me a bit more ground clearance. Not sure I'd see a huge gain but it's tempting
Reactions: Napaul
Napaul
Napaul
56
112
Wow 900 miles? How’s your alignment? I’m in Northeast Georgia so it’s a mixture of hardpack, loose soil, mud, clay...I also live in a small rural area near an old flood plain so throw in a ton of granite outcroppings and more sand than you usually find in NEGA. I have a ton of places to ride but have to hit the pavement at least for a mile or so to get to them. Sometimes farther. I literally run the gauntlet of terrains! That’s why I’ve researched tires so extensively. There’s just nothing out there that will do it all. I’m going to have to make sacrifices somewhere.
Napaul
Napaul
56
112
Do you have the SATV A-Arms? I’d love to go 30’s but I wanted to avoid buying A-Arms for now. At least while my stock ones are still undamaged.
ToddACimer
ToddACimer
Pioneer 1005-2
3,549
14,537
Oshkosh, Wi
Yes I have SuperATV arms.
IMG 20191019 171617
Reactions: Napaul
ehart814
ehart814
1,654
3,643
NWPA
I dropped the pressure in the Federal 235/75/15 tires yesterday to 9 psi. It made a huge difference in the ride. Much smoother and I bet it will get around better.. I didn't get off road yesterday to test. The sidewall is much more flexible than I expected after I lowered the pressure. The tires were at about 14 psi and they were very stiff.
Napaul
Napaul
56
112
Definitely keep us updated how they do with the extra flex. This is something I’ve been really interested in with the beadlock vs no beadlock debate. Just googling, I’ve stumbled across another UTV forum where a couple users swear up and down that they’ve ran LT tires at 10 psi for thousands of miles with no beadlocks over rocks and everything else you can think of without a single issue. But I don’t fully trust people on forums who don’t own Hondas!
ehart814
ehart814
1,654
3,643
NWPA
I was reading a razr forum about these tires before I bought them and saw similar things. The razr guys have been running them for years. More info there about the LT tires than there is here. I found that as I was deflating the tires, they were starting to flex noticeably as I approached 9 psi. When you start to see the bottom of the tire flex to the ground, you're getting close. It really is a big difference in ride quality.
Reactions: Napaul
