K&N intake
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
My k&n intake is supposed to arrive today. While considering buying it the question I asked everyone on Hondasxs.com that I knew had one was, "does it help? Is there a noticeable power gain?" Everyone here was helpful as always (thank you!) and most said they thought it helped a little. I am a numbers guy and I want data I can analyze to gauge power gains, so my plan is to time ten 0-40mph runs with my stock CLEAN intake and determine an average time. Then I will install the k&n and do the same. Granted my timing method will not be spot on accurate (stopwatch on my phone) but I think taking ten runs and averaging them will give a good representation. I will post all times and my conclusion in this thread so if this is something you've considered getting but just aren't sure, stay tuned!
64,828
Interested in your findings as I am running a K&N too..
Lynn
Lynn
263
134
Yakima,WA
Great . I did that when I started my supercharger project. I think I saw a 8% increase in acceleration with just the K&N filter. Not sure memory fails sometimes. Looking forward to what results you com up with.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Wow 8% is pretty good I think. Now I'm wishing I had baseline numbers as well (stock tires, stock exhaust) but oh well. do you guys have the filter cover too?
64,828
I didn't know you had one. What was your impression of it?
Seemed like a faster throttle response time. But really I cant say much for overall. Need a muffler to benefit more.
bobbyhill
bobbyhill
Junior Moderator
1,271
952
Smithfield, VA
I hope you complete this before the Snow starts to drop up here because that is when i plan to start all my big projects and i plan to throw a K&N Filter in to that mix too!
wyo700
wyo700
413
210
I noticed a slight difference in throttle response and I did notice more of a throaty sound coming from the intake. I think you will notice difference.
classichonda
17
9
A word of caution on the K&N filters. They stop in the neighnorhood of 97% of dust vs. "paper" style filters that stop in excess of 99% of dust. If you're riding in dusty conditions that can be the difference between a healthy motor and a major repair bill.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Yes I have read all about this. All the comparisons I've seen are looking at k&n vs. paper filters. I haven't seen one compared to a "wet" foam filter like our Hondas have. Just to be safe I am going to be running filter skins too. I'm not too worried, I've run k&n's in almost everything and never a problem.
wyo700
wyo700
413
210
Same here. I have a k&n in everything I own and have never once had an issue. With all the atvs I have owned and now my pioneer I have always ran with the outer wrap pre filter.
Reactions: joeymt33
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Ok the results are in! First some stats on my machine and other things of note-
2014 P2
26" tires at 6 psi
Yoshimura exhaust already installed
All runs in 2wd
Temp. during test 89*F
Elevation 100ft
My average time from 0mph (at idle) to 40mph (full throttle) with stock intake was 12.7 seconds. Time averaged from 9 runs.
Average time with k&n was 11.5 seconds. Time averaged from 5 runs.
So with the new intake I'm getting to 40mph a full 1.2 seconds faster on average! Money well spent!
wyo700
wyo700
413
210
Wow that is a huge improvement would have never thought that. I still have my yosh exhaust I wish it wasn't so damn loud or I'd put it back on.
bagotaco
bagotaco
121
77
Nice improvement. K&N filter is now going on my to get list.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Yes I was surprised too. Ill put it this way, the reason I only did 5 runs with k&n instead of 9-10 was because my times were fairly consistent and I was tearing up my road too bad! Way more wheel spin on launch. I have read the hmf swamp series exhaust is pretty quiet, maybe something to consider.
Reactions: Simpleman
bobbyhill
bobbyhill
Junior Moderator
1,271
952
Smithfield, VA
2014 P2
26" tires at 6 psi
All runs in 2wd
Elevation 100ft
So with the new intake I'm getting to 40mph a full 1.2 seconds faster on average! Money well spent!View attachment 5705
Great info!! Thank You
TimmyBoy84
TimmyBoy84
56
34
Southern California
I put on the K&N and the Yoshi pipe before heading out to Pismo Beach and the sand dunes and I noticed a good amount of low end, off the line and better hill climbing power than stock and that was with no paddles. I'm hoping the Dobeck system makes even more of a difference with all 3 together. I kept up with my buddy who has a built rhino until we hit the whoops and thats where he left me and my stock suspension in the dust :(.
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
Shm come on!!!!!!!!!! Alost a second and a half off of a 40 time tflynn i really gotta call that unless the stock filter was pluged solid or ur getting paid by k&n there is no way in hell i can yes yes you will def see a better throttle response no doubt there and with your exhaust yes it will help breath but no way will a filter alone give you that and @Lynn s 8% maybe at off throttle response with his 12v hair dryer WHOLE dif bag of worms but comeon man!!!!!!!!!!!!!!!! I gotta call bs on that one and its no disrespect i love your ride but no way and i buy those numbers
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Hey man don't know what to tell you. Those are the times I got. Keep in mind it was with an exhaust already installed. You can believe it or not, I have no reason to fabricate numbers. But now that you mention it... Maybe k&n SHOULD be paying me for this write up!
