P1000 Key On Power, Illumination, and backup source! - 2016 through 2021 Honda Pioneer 1000 Only
68,409
@Hondasxs . The three aux switches on 22 deluxe. Where is the termination end on those 3 ? It looks like they go under the front plastic, Do they double back and end in the big blue ball of tape Near the fuse panel?
Yes. There are 2 blue tapes. 1 is the switches, other is the new key-on power for 2022 models.
Reactions: ODAMO and Smitty335
ODAMO
ODAMO
1,399
3,673
Ohio
Thank you. Just like the other Honda owners manuals the Pioneer owners manual has a bit to be desired. EG: In the manual it says "Using the wrong oil filter may result in leaks or engine damage" But I have yet to find where the right filter is listed.
Without the few online places that list 2022 Pioneer 1000 parts AND You and all the other enthusiasts here things like this are harder to figure out. Thank you again 😄
Jsaint
6
Germantown TN
According to Honda Accessory Instructions. Here is the recommended location for Key On Power for the Honda Pioneer 1000 Side by Side!
Honda suggest tapping the 15A Acc Fuse on the output side. Here you will find 2 WHITE with a BLACK STRIPE wires coming out of the output side of the fuse. You will need to untape the wire bunch to access them. It is recommended that you use a posi-tap (not shown) vs the wire tap-ins (shown) for a better error free connection.
Hey @Hondasxs i ordered the rear led lights with the trigger switch this week. I was gonna find a fuse running off key on power and use a fuse tap to supply power. Should any key on fuse work? Should I solder the connection point or crimp it and shrink wrap it? Thanks for the help don’t do much electrical work myself.
Jsaint
6
Germantown TN
It’s a 2024 base model p1k5…
Fatsquatch
Fatsquatch
Approved Member
121,572
1,013,516
Hidden
The site store sells a key on power harness. Its plug and play if you are not real comfortable with electrical.
Reactions: Jsaint and Red500
Jsaint
6
Germantown TN
Yea I saw that and grabbed one too 😂. Was wondering as I looked at the wiring diagram if I should install an in line fuse from the key on harness to the power, that’s when I had the idea to just use a fuse tap….
Reactions: Fatsquatch
68,409
For the 2024's. The ACC port top right of the battery will give you 12v to power the rear lights.
That is until you add more accessories and move to a fuse box.
Jsaint
6
Germantown TN
Hey that’s an even easier idea. I’ll save my key on harness I ordered for a blinker kit or something and use this for the rear lights. Thanks m
MoneyMaynard
Huntington WV
  1. 1000 6 Crew
If it's the one I found with a white wire with black line and a grey wire clear connect with grey plug, it's a little hard to get to but not to bad, shouldn't have to take the floorboard out.
IMG 1832
Reactions: ChadD
L
ladr22
Southern Indiana
I traced some weird issues we were having with our 2016 1000-5 to a bad/intermittent contact for the powertap for the accessory fuse box/circuit board (SWITCH PLATE/VOLT METER/WIRE HARNESS P/N 0SA30-HL4-100). I purchased the key on power harness from the sxs shop with the intention of using that instead of the sketchy power tap at the fuse box. My dilemna is that that the wire that should be "switched" power leading to the accessory circuit board has 12V when the key is off. Could I have a bad relay on the circuit board? The only accessory currently on the accessory board is a heater fan and it does not currently switch on. Was going to add an interior light to the circuit board as well.
DRZRon1
DRZRon1
1,451
4,435
PA
Yes - could be any of the above, need to troubleshoot it
68,409
Find someone to help you turn the key on/off while you listen/feel the relay on the board.
It should be noticeable click.
L
ladr22
Southern Indiana
Good idea. The continuous and rapid clicking of the relay was the original problem due to the intermittent contact at the power tap.
