KFI High mount - Winch Mount - P5
admin
admin
Your club! I just turn it on!
317
KFI Products has released there new High Mount - Winch Mount for the Honda Pioneer 500.
Its mounts above the bumper keeping it more out of the elements then the OEM mount.
And not bad priced at $55.00.
Designed to work with the following Winches:
KFI: ST17 / S2000 / A2500 / A3000 / U4500 / U4500w / SE25 / SE35 / SE45
WARN: A2000 / A2500 / U2500 / 1.5ci / 2.5ci / 2.5ce / 3.0ci / 3.0ce / 3.0s
WARN: RT15 / RT25 / RT30 / XT15 / XT25 / XT30
WARN: RT40 / XT40
WARN: Vantage 2000-4000lb
WARN: ProVantage 2500-4500lbs
RAMSEY : ATV2500 / ATV3000
SUPERWINCH : Terra25 / Terra35 / Terra 45 / LT2000 / LT2500 / LT3000
MILE MARKER : PE2.5 / PE 3.5 / VMX2.5 / PE2000 / PE3000 / PE2500 / PE3500
CYCLE COUNTRY : Work Power 1500 and 2500 / Powermax 2500 and 3500
BADLAND : 2000lb #68146
- Requires the correct Fairlead with a 4.875" Bolt Pattern (available if needed #ATV-RF)
- Listed Models come with incorrect ATV Roller Fairleads
BADLAND : 3000lb #68145 / 5000lb #68144
CHAMPION : C10013 / C10014 / C10018 / 10020 / 10024 / 12053 / 12503 / 13501(reqires rollers) / 14061
CHAMPION : 14501 / 14551 / 14552 / 40252 (4500lbs)
CHAMPION : 10028 / 10032 / 12001 / 12002 / 13001 / 20049 / 20051 / 20249 / 30045 / 30145
CHAMPION: 14001 and 14061
KEEPER CORP. TRAKKER : KT2500 / KT3000 / KT2500C / KT3000C / KT4000 / KT4000C
KEEPER CORP. TRAKKER : KT2000
- Requires purchase of a roller Fairlead (KFI #ATV-RF)
SMITTYBILT : XRC 2.0
SMITTYBILT : XRC 3.0
XGEAR: X3000 / X4000
- 4-Hole Standard (3.00" x 4.875" bolt pattern)
VENOM: 2000 / 2500 / 3000 / 3500 / 4000 / 4500 / 5000 (Hardcore Series)
- All with 3.00" x 4.875" Bolt Pattern mount-up
- All with 3.00" x 6.600" Bolt Pattern mount-up
Possibly Many others with the below standard Mounting patterns (call to confirm)
- 4-Hole (3.00" x 4.875" bolt pattern with Rollers that are 4.875" bolt pattern)
- 4-Hole WIDE (3.00" x 6.60" bolt pattern with Rollers that are 6.600" or 6.000" bolt pattern)
- 2-Hole (3.10" with Rollers that are 4.875" bolt pattern)
Specifications:
100% MADE IN USA
Mounted up higher to keep it out of the elements and allow it to fit larger winches
Constructed of 3/16" steel
Unlike all other mount competitors our mounts are metal bead blasted before they are powder coated for the best possible finish prep.
Powder coated black for supreme durability
Very easy to install
Complete installation instructions included
All mounting hardware included
Satisfaction guaranteed
Roller fairlead and winch not included
Be the first to review this product!
Price: $54.95
Product Code: 101215
http://kfiproducts.com/index.php?_a=vie ... ductId=571
Crookedcreek
66
22
I purchased this same KFI mount because of the high mounting position. Just assembled it to my P500 on Sunday and mounted a Superwinch Terra 35. I like the way it looks and it seems plenty sturdy. My KFI plow mount, push tube and 66"snow blade should be arriving at my dealer in the next day or two (fingers crossed!).
I'm thinking the high mounting position will have a second benefit of providing a higher lift position (ground clearance) of the blade when backing up or pushing the top of a pile of snow, and general transport to and from the push area (like across my yard from it's home garage). It also provides a certain amount of "protection" for the radiator, and I don't think it will restrict air flow to the radiator to any significant degree.
Stoney
Stoney
111
549
Alberton, Montana
Just installment KFI High Winch mount with the KFI 4500 lbs Stealth winch. took me about 3 hours total with juice breaks and snack breaks thanks to my 4 year old assistant. pretty please with ease that it was installed. easier than mounting factory Can Am winches that's for sure.
slacker
this is a really quality mount, looks like a factory item, after seeing this post, I ordered one off amazon to do my winch install, its a VERY nice mount that places the winch in a very good location
Photo zps3830211c
Photo zps48c10af4
sam3006
sam3006
144
411
Damascus, AR
I moved my winch from the low factory mount to the high KFI mount today. Like it much better and it's a lot easier to install than the factory mount, the winch is also easier to install on this mount. The winch is higher so it should stay out of the water and mud better. It's behind the bumper and protected, but still more in the open so it's easier to operate the winch and it also shouldn't get as packed with mud and dirt as the low mount did and will be a cinch to clean off now. Didn't take pictures, but it looks just like slacker's pictures above, except my 500 is red and the winch is a warn. I did have to buy a separate fairhead mount, to go between the mount and winch, to bolt the fairhead to, about $20.00.
BDI01
BDI01
19
37
Has anyone noticed any radiator airflow problems with this high mount.
Sxsnewbie
Sxsnewbie
298
103
Eastern Connecticut
Was waiting for the airflow thing to come up.. That's the only thing that has really kept me from moving it
sam3006
sam3006
144
411
Damascus, AR
I don't think it will block as much air as my spare tire mount, see my avatar, and I ran my 500 all summer with the tire in place and never had any over heating problems. I've only run the 500 in temperatures below 70 since adding the high winch mount, but don't think there will be any problems. It sits well in front of the grill and doesn't block that much of the total area, not nearly as much as my tire did. Only thing now I've got to find a new place for the spare, but I thing I'd rather have the winch more accessible and up out of the mud than I having the spare on the front, although it made a great bumper.
Code54
Code54
583
626
Hurricane West Virginia
I personally believe the fan should easily make up for the reduced airflow, plus there is still a lot of surface area for cooling.
63,988
After riding with a few 500's this weekend. I will say the bottoms filled up with mud fairly quick. The top was clean. None overheated. I don't think the winch would be so restrictive that the fan could not compensate.
