P1000 Larger battery, or dual?
MontanaBighorn
MontanaBighorn
121
214
Billings, MT
CarryGuide.com
Dh
My '20 P1K5D is so dang perfect for my needs that there are very few mods I'm doing. To eliminate the possibility of burning up my clutches while winching, I want to either do a dual battery set up, or replace my OEM battery with one large enough to power everything simultaneously. I can see advantages with either setup, and the dual seems more complicated, although certainly doable.
What is the superior choice, dual batteries or one large, and why? Any particular battery/ies? I want every decision I make on this machine to be an informed one.
Thanks,
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
personal preference. im running a full size marine battery 800cca on my 700-4 but it sits in the bed behind the seats. can run radio for hrs then crank up and leave.
Pilotadam
Pilotadam
326
735
Pell City, Alabama
Honestly it's all personal choice on how you use your machine. I have a dual set up with a full size marine Optima Blue top under the seat. But I do have pinching when I need it to climb rocky trials plus I run LED light Bars and a stero. On my previous Teryx that did not have the clutch problem caused from low batteries I had a single battery but had a problem a couple of times when I shut it off the battery was to low to restart.
TripleB
TripleB
11,935
101,311
Caryville, Tennessee
I have the dual set up. It was pretty easy to do with all the threads on this subject. U just have to some digging. I dont think u can go wrong either way.
Reactions: CumminsPusher
63,988
No need for either. In my opinion.
You have a 2020 and the 2018 update has about eliminated clutch issues outside of the big bogger guys.
Another thing is being conscious with your winching. Try to limit off/on throttle while winching. Many manufacturers state you should let the winch do its job and not apply throttle at all. Doing this will have no effect on the clutches.
This would then make the concern a dead battery. My need for key-off accessory usage is why I chose a dual setup.
Chevy, Ford, or Dodge. They all will get you there and back. Most of the time. Lol.
320,459
Personal opinion but I say dual. The Pioneer is so voltage dependent it’s nice to eliminate anything you do from the factory equipment.
Even if you run stereo/lights dead the machine will always fire. Run winch and battery gets low the clutches will still engage without worries, can run both when needed much more comfortable. Separate the two and your much less likely to have issues with the important one.
17LE
17LE
79
202
Iowa
Can you tell me if my new 17 has this update or how to find out for sure ??
Thanks.
