Has anyone found an aftermarket cup holder that is bigger around to handle insulated cups?
I had the stainless cup holders and replaced them with the black plastic ones because they are a little bigger on the inside and my mug fits better even though they claim to be the same size.
Bigger as in around or deeper? Because it would be nice if my yeti koozie would set flatI had the stainless cup holders and replaced them with the black plastic ones because they are a little bigger on the inside and my mug fits better even though they claim to be the same size.
Bigger around, the difference is very very little but it is enough that it will not grab my wife's water bottle or my coffee mug.Bigger as in around or deeper? Because it would be nice if my yeti koozie would set flat
I went with the Polaris Ranger inserts. They will hold a Yeti cup and just about any bottle or can up to 1 liter size. They fit perfectly after a little trimming with a box cutter and they have a factory look. A bit pricey but they work. Fix My Toys sells 'em. Part # 5436836.
Trim the dash a little at a time. The plastic slices really easily once you get started so be careful not to let the blade slip.Sorry
Sorry to resurrect an old thread, but did you have to trim the dash or the cup holders? Trying to decide which cup holder mod to try.
