P1000 Leaking radiator, broken fan
wrwtexan
wrwtexan
328
890
Northeast Texas
Have a customer's 2016 P1K-3 in shop for coolant leak and a shattered fan. Pulled radiator and couldn't visibly find a leak but I blew into it while covering outlet and found the top tube to be split for about 4 inches. Will take a new rad. No external driver induced injury.
20200318 210506
P1000_DLux
P1000_DLux
Its Only an Opinion Relax
Belfair, WA
How did that happen. Fatigue over time? Hit something?
Reactions: Isaiah
wrwtexan
wrwtexan
328
890
Northeast Texas
No idea. Had thought his hand had backed a stick into it but not sure. Little over 5k miles on it. I figure fatigue on crack. Makes me nervous about my '16.
Reactions: Isaiah
7,134
27,093
@Montecresto had a similar failure in Colorado. The fan began making a little noise ,like it was out of balance. The next day it got quite a bit worse. I attempted to turn the fan ( with machine off but warmed up) and found the blades to be soft and flimsy. After the ride we dismantled the machine and replaced the fan and shroud. I suspect the fan bearings got hot and caused the fan blade to become soft. When it would run it had a heck of a unbalanced condition. It only had 1 blade still intact as well.
P1000_DLux
P1000_DLux
Belfair, WA
Well something to look out for in the future, thanks.
Reactions: PJon and Isaiah
P1000_DLux
P1000_DLux
Belfair, WA
Looks more beefy than the stock fan.
Reactions: ToddACimer
E
Ericthered
Eric The Red
271
522
Sparks, NV
Can you give dealer and part number for fan. Mine vibrates when hot. In Nevada that's 8 months a year. Thanks, Eric in Reno, NV.
0
0860silverado
945
1,813
louisiana
Exactly what I'm chasing down right now!
