P1000 LED Headlights
russknight
russknight
1,910
7,506
Perry Florida
Are the factory LED's much brighter than the halogens? Are they worth the money to upgrade to them?
YardDog
YardDog
Grumpy ol' fart
617
1,937
Arkansas
I swapped out my halogen bulbs with Genssi Elite H13's. I don't know if they shine any further or wider but the crisp white is much better than the yellowish glow of halogens. I had to stretch the springs on the headlight adjustment a little but otherwise it was plug and play.
sporttrac4x4
sporttrac4x4
1,177
2,082
ILL.
BEAMTECH H13 LED Headlight Bulb, 50W 6500K 8000Lumens Extremely Brigh (9008 Hi/Lo) CSP this is what I use works great.
bowhunterbill
bowhunterbill
414
1,278
Bozeman, MT
I want to confirm that these H13 led bulbs were a replacement for the P500 factory 862 headlights. I just spent 30 minutes on Google searching for a headlight cross-fit table and struck out. Hence my question.
I installed an led light bar pointed right in front and the stock headlights pointing forward are almost yellow in comparison.
sporttrac4x4
sporttrac4x4
1,177
2,082
ILL.
I have a pioneer 1000-5 2016 I don't know about the p500. H13 led bulbs is for the pioneer 1000.
sporttrac4x4
sporttrac4x4
1,177
2,082
ILL.
I think 881 led is 862
bowhunterbill
bowhunterbill
414
1,278
Bozeman, MT
Thanks. On amazon the merchant says 881 led fits 862.
F55d05a725da0681f3a6b8c19b84de41
I’ll give them a try.
Reactions: sporttrac4x4
bowhunterbill
bowhunterbill
414
1,278
Bozeman, MT
The 881 led fits a P500.
Much whiter, I can’t say about distance visibility differences until I get it out at night.
Thanks for the help.
029d64c2d72944d20710e722ffb65e89
russknight
russknight
1,910
7,506
Perry Florida
I installed the LED's and the low beams are great, the high beams not so much. Are the factory LED's brighter than the LED replacement bulbs?
bowhunterbill
bowhunterbill
414
1,278
Bozeman, MT
I did a night ride and while the led bulbs are whiter, it’s hard to tell if I had better visibility 20 or 30 yards in front. However, when I flipped on my 30” light bar it looked like daytime in front and it didn’t matter.
Since I’m not looking for highway lighting, but holes and rocks on atv trails when I’m hunting and driving in pitch blackness- I’m calling it good.
BTW I installed a 5 led license plate light for my perm license, and it does a nice job giving some illumination when backing up.
207,989
Pictures please!
320,412
In my opinion yes. LED doesn’t have the penetration of halogen or HID. It usually requires more bulbs for the same light. For a LED to project correctly it requires separate reflectors for each bulb. That is why led housings have the burners spaced apart and separated instead of multiple in one housing (like putting a replacement bulb in halogen housing) that way the light can be focused better.
Factory bulbs in the Pioneer are very low power so the LED is slightly brighter then the halogen but it’s because LED is more efficient. Just can’t focus that light which kills penetration some.
As far as replacement bulbs I’d suggest HID which is far superior for penetration power but in halogen housings it does scatter the light a bit. The factory LED headlights are designed around LED so they do work pretty well. There are also aftermarket replacements for the Pioneer that are close to a third in price. If running on the road much I’d suggest those. For trail use just turn off those power robbing headlights that don’t really do much anyways and get some spot/flood LED bars and be done with it.
russknight
russknight
1,910
7,506
Perry Florida
I had the lamps adjusted (they have a rotational adjustment) incorrectly. Now they are so bright people flash me when I have my low beams on.
Reactions: CumminsPusher
207,989
On stock LED's?
