P1000 LED Headlights
320,409
So we’re they not adjusted with the factory bulbs then?
Reactions: russknight
bowhunterbill
bowhunterbill
414
1,275
Bozeman, MT
I had the lamps adjusted (they have a rotational adjustment) incorrectly. Now they are so bright people flash me when I have my low beams on.
How were the led’s adjusted (rotated?) when the 3 slot clip is keyed (one is larger)?
russknight
russknight
1,910
7,506
Perry Florida
https://amazon.com/gp/product/B073ZDLKT9/?tag=sxsweb24-20
If you hover over the picture, you'll see a very small allen head screw with a series of holes in the black plastic part of the lamp that locks into the reflector housing. This enables the lamp to be rotated 360 degrees and set in a number of different positions. Also notice the way the individual LED's are arrayed on the lamp. If installed out of the box without removing the set screw and setting both lamps so the LED arrays are positioned the same on both sides of the buggy, the light pattern will be different on each side and thus scattered. These are really bright lights and make a big difference over stock.
bowhunterbill
bowhunterbill
414
1,275
Bozeman, MT
Pictures please!
LED headlights
Acc9bf65df17de09719f469ef7382f93
Plus 30” led bar above cage
Db8220b526516a989d31f4b1b59a502e
