P700 Led lightbar making noise
P
Putty1985
Fort plain ny
I wired up a 32” nilight led bar to the front of 700. I bought the Honda accessory harness. My lightbar is ran to my switch panel, which is ran to a fuse block. The fuse block is wired to the accessory harness. Whenever I turn the lightbar on I get a very high pitched noise that comes from the lightbar and the voltmeter drops from 14 to 12.4. The rear pod lights I installed do not make any noise, and the voltmeter doesn’t drop at all when they are turned on....all of the lights are wired the same way....any ideas as to why it keeps making this noise?
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
Sounds like maybe wiring problem or faulty light. Unless its just pulling unreal amps. Being led im guessing something with the light. Id expect a few tenths lost from it but not over a volt.
farmtimpioneer
farmtimpioneer
Wise Men Still Seek "Him"
549
2,079
Brookville Ohio
Are You turning on the lights with a switch and relay or just the switch, if You are going through switch only the switch may not be rated for enough amperage for light or to small a wire at the switch, switches should be used to trip relays only, accessory power goes through the relay directly from fuse block or battery,,,,,,
Reactions: Slackjaw
