P1000 LED lights
Hudge
Hudge
45
50
Farmington N.M.
Has anyone bought those lights off face book and r they any good the price is right but are they worth it
tig
tig
116
176
They are more expensive than the generic lights on eBay and they look to be the same thing. I'd check ebay before you pulled the trigger on anything off facebook. Remember they're paying for those ads to get to you and they certainly aren't free.
322,690
@tig said it perfectly! We've got something like 1900 transactions on eBay we build everything that way even xmas and clothing it makes this all possible! From everything I've seen eBay has best selection as well
Reactions: Hudge and drfubar
322,690
Who was the cat that mounted his light in the front bumper?
i did. There are a couple others too
Reactions: joeymt33
Riverrat
Riverrat
86
234
UP of Michigan
CP what bracket did you use and does your light have the mounts on the bottom or each end? I just got the nilight 12in with mounts on bottom, it don't seem to fit, I'm thinking I should have got the one with mounts on the ends.
Reactions: dotman1
322,690
One minute
322,690
Post #83 CumminsPusher the new ride is the mid bumper mount. It should fit with minor adjustment:) it fits excellent if you bend the lip a bit. Adjustable pliers do the trick. Just use a towel so you won't mar. With this setup you won't need other mounts and it fits snug and out of the way. I spend LOTS of time in r&d:) I reposted because for some reason it's hard to find
