P500 Lift Kits for a Pioneer 500
TonyPrusaczyk
TonyPrusaczyk
5
Harrisburg, IL.
I want to lift my Pioneer 500. What do you recommend. I live in Southern Illinois, where I have all types of terrain. I'm getting ready to all 27" inch tires and a 3000 lb. Winch to it.
34,173
I recommend you don't lift it, they're tippy enough as it is. You can go with 25-26" tires ( on stock wheels ) at under 10 psi and get an inch or two of clearance and maintain about the same as stock stability.
Reactions: Islander
ChuckIII
ChuckIII
96
155
I have 27s on stock rims works great no problems at all. I kept 10 wide in rear and 8 up front. 10 psi in each. Goes anywhere!!!
IMG 20160309 142610170 HDR
Tmiller
Tmiller
51
64
New york
I'm running 28-9-14 all around went up 1 click with rear springs and unhooked swaybar I couldn't be happier almost 12" of clearance amanzing handling and not tippy at all
p500fan
p500fan
418
358
Sand Point, AK
I'm running 27"x11" Ripsaws on all four corners. No lift, no frame mod. Never rubbed, and have full lock-to-lock steering. Been very happy with it. Have not noticed a measurable loss of power, or stability.
906UP
906UP
12,994
121,109
da Yoop
I'm running 27" Terrabites, no problems
Twangin
Twangin
131
275
NC
I'm running 28-9-14 all around went up 1 click with rear springs and unhooked swaybar I couldn't be happier almost 12" of clearance amanzing handling and not tippy at allView attachment 13019
How does the P500 handle those big 28’s? Did you lose much power for climbing hills or did it affect trail riding any?
906UP
906UP
12,994
121,109
da Yoop
Seems like that' the way to go then I have to get off the ground a little more. Do they make it much wider?
I went with new wheels with the Yamaha style offset, 4+3, at the same time so it is wider. It seemed like it calmed it down, made it smoother shifting, driving, etc. I'll see if I can find a picture
20170805 152947
Reactions: Chuckerbird
NPN
NPN
96
192
Manitoba
I have 27s on stock rims works great no problems at all. I kept 10 wide in rear and 8 up front. 10 psi in each. Goes anywhere!!!View attachment 12219
Hi just wondering if you are still happy with your tire choice? Would you do anything different? How much clearance do you have at the rear hitch to ground? Thanks!
ram5451
ram5451
11
5
Tallahassee
I have rip-saw 27" tires all way around no spacers, did go with 4" off set rims. We have no rub and rides well.
Soon as can get pic's downloaded, I will try and post. New to the forum so bear with me.
Thanks
Robert
Reactions: Chooglin
jmcampbell54
292
628
Texas
So I’m thinking of going 27x12x12 rear and 27x9x12 front on factory wheels. Question is will 27x12x12 work for the front if I do 2” spacers all around. Does the collective mind think that is enough offset to not rub in the front?
155,936
I would think you're good. Most tires don't run true to size anyway. I'm curious if true 28 x 10's would fit without rubbing?
