P700 Light Bar and Mount
7,139
27,144
Thanks or the info. I also have a spare and ice chest on the back. I also have neck problems, so this will help with backing and also help with keeping track of my trail buddies.
Reactions: Tflynn
SuperYeti
SuperYeti
220
375
Vancouver, BC
Definitely, now to decide where to install. I was thinking down low, as it would be easiest to wire, but i don't really trust the waterproofing on the cheap China camera and suspect the first water crossing and it'd be pooched. Also I'm about to embark on building an exhaust silencer, and if i didn't waterlog it, pretty sure i'd melt it with the additional exhaust heat. So that leave up on the ROPS, which will be a super big pain to fish in new wire, but not seeing much other options, now to track down some decent quality RCA coax, and some thinner power wires to get everything back there.
eastenn
eastenn
220
469
Bristol TN
www.fb.com
I don't see how you managed to tighten the bolts holding on your switch panel unless you had help.. I would recommend pop rivets next time you have it off
SuperYeti
SuperYeti
220
375
Vancouver, BC
*MAGIC*
LOL, I removed the windshield, and am 6'6" tall, was able to do it just fine on my own. Though, there was MUCH cursing lol. Pop rivets might be an option, but I'd still need to get behind to put a washer for the pop rivet to bite on to, that plastic in that area of the dashboard is anemic at best.
eastenn
eastenn
220
469
Bristol TN
www.fb.com
That had to been challenging... yeah I agree the plastic is weak but the larger pop rivets have worked well for me with no washers. Although I'm about to be drilling them out to add more lights and switches to my rig
Tri2hunt
14
27
The Woods
The back up camera sounds like a cool addition.
Nice setup on the lights and switching.
I suggest riv-nuts or nut-serts, they are called something like that, as a way to attach the switch panel and have the ability to remove it when needed without the difficulties.
SuperYeti
SuperYeti
220
375
Vancouver, BC
Ya unfortunately the plastic is too flimsy, I will probably do a mounting ring behind it and tap it. I'll probably leave it until I need to get back in there, so whenever I get around to building the cab, and heater
JimmyA
JimmyA
1,644
5,503
Northeast texas
Nice! I would hire you to do mine, distance makes it unavailable! I have been up there, "Rainey Lake" at "International Falls", Great Scenery.
CaptainFlash
CaptainFlash
0
Louisiana
So from the accessory harness that goes to the relay from the relay to the fuse box what the powers it on, then from the fuse box to the switches from the switches to the accessories.. right?
Spoonbill
Spoonbill
213
262
East TN
Well I finally got the new mount for my light bar built, and all the lights mountedl Took some pics for reference.
Started with a cardboard template, then cut these 2 plates out of some 1/4" mild steel plate with the bandsaw and grinder, then drilled.
Took a chunk of 2x2x3/32 square tubing and tacked between the brackets, here's a fit up test before welding and drilling for the light.
Light mounted. still can open the front window a bit, and can still add on a front rack later on if i want.
Rear floods mounted.
Have to pickup another fuse block as I used the one I had earmarked for this project on the boat last week, will post more updates as I progress.
Where has everyone else ran the wiring for rear lights? I was thinking down and under all the way up to under the front hood, but am open to suggestions.
Cheers
Im
Going to run mine on the inside of the ROPS as once hunting season is open the undercarriage will be exposed to rice, soybean straw, mud, etc.
Spoonbill
Spoonbill
213
262
East TN
Im
Good morning from East TN. I am just starting this wiring and accy. Gig. I know I need to add another fuse block, but how do I determine if I need a relay as well ?
