P1000 Light Bar Wiring
Johnny787
45
72
NC
How are y'all running the wires for light bars and stereos that are mounted overhead? I don't want to drill my cage, but at the same time I don't want to zip tie wires up my cage either. Anyone have any pictures of their installs?
K
Kolton
117
82
Vance, al
If your worried about seeing the wire you could use black shielded wire. I took my roof of and wired the speakers where the roof covers them. You only see speaker wires on the front by the driver side.
Just cover them up with mud. That’s what I do.
Cbba595dd61f157e78833b44390a187c
Reactions: ohanacreek
But really, if you run them up the passenger side tied inside the roll cage, it’s barely noticeable. But some people have drilled holes in the roll cage to run the wires all the way up.
Johnny787
45
72
NC
Thanks. I want it to look at clean as possible. I know it will get muddy and all, but I don't want wires to be caught in trees either.
I went through same thing you’re going through right now. I really didn’t want them visible but at the same time I did not want to weaken the roll cage by drilling holes in it. So I ran them up the passenger side rollbar but to the inside so it did not hang on anything and it has been fine for me.
Reactions: ohiohunter
One other thing, some guys run them under the floorboard and up the roll cage behind the seat so it’s much less noticeable.
Johnny787
45
72
NC
Did you zip tie them?
I did. I used the zip ties the late flat and don’t have the knuckle on them.
They are called low profile zip ties.
43150ce68c868d76ef33ea912fd02610
Reactions: jinx
