P1000 Light duty Front Bumper from scratch.
slowdryrider
slowdryrider
572
778
Canada
Got tired of the old look . So using some 18 gauge from the hood of a old square baler and some light tubing from a tread mill I made this bolt on bolt together front bumper . Sure added a beefier look to the machine. Used cereal box to mock up then transfer to the metal .
IMG 5150 IMG 5155 IMG 5160 IMG 5163 IMG 5164 IMG 5166 IMG 5167
115,291
NorthernJoe
NorthernJoe
355
1,356
Northern Ontario
View attachment 376945 View attachment 376946 View attachment 376947 View attachment 376948 View attachment 376949 View attachment 376950 View attachment 376951
Awesome Job!
Now I may have to go and do something like that
NorthernJoe
NorthernJoe
355
1,356
Northern Ontario
Slowdryrider
What you did to your ride has really improved the look. My stock bumper is slightly different then yours, but it still had that wimpy look with the single bar out front of the tire. Here is what I have mocked up. I do not have an old square baler laying around, So it will take a bit of time for me to make it from metal. I like the look so much that I am going to do a similar box bumper on the rear
Joe
IMG 8691
IMG 8692
IMG 8695
slowdryrider
slowdryrider
572
778
Canada
Slowdryrider
Joe
View attachment 378364View attachment 378365View attachment 378366
It sure makes the machine look way nicer . I have a rear bumper [home made ] already and have also thought of changing it up a bit as well . BTW you've taken time to cut wood for your mock up .Now that's classy , compared to me just using cardboard . Going to look nice when it's done .
NorthernJoe
NorthernJoe
355
1,356
Northern Ontario
Thanks, I usually use cardboard like you, but it wouldn't hold its shape for me to figure out the angles. Now I have a solid model to take to the local metal shop when they bend the steel for me
Ericseabaugh
Ericseabaugh
274
2,256
South Central Illinois
Very good job, it looks great. I dug up a piece of 11 gauge outta the steel pile 2 weekends ago to do the same build somewhat except I will leave the winch behind the bumper.
NorthernJoe
NorthernJoe
355
1,356
Northern Ontario
Well it took awhile to finally get to it, but here is the end result.
It is formed out of 1/8" thick steel and the back side is boxed in around the factory "pipe"
IMG 9953
IMG 0101
IMG 0103 2
IMG 0104 2
IMG 0105 2
I just have to finish hooking up the marker lights
The tailgate opens and the bumper does not hit the exhaust when the box is up
Mopower58
Mopower58
CST is the Best!
79,420
706,154
Crystal Springs,Ms.
WagginTail
WagginTail
1,577
5,827
SC
EMAW
EMAW
Mama Tried!
3,410
43,101
Kansas
