LIGHT INDICATOR
Capitan
20
27
Friant, CA
My 4-wheel indicator on the display does not reflect the front wheel drive when I place the unit in 4-wheel driver.
Any suggestions as to why this is not functioning properly?
Thank you
212,761
Thank you
First thing I would look at is the shift cable adjustments, there on the drivers side, rear floor board under a panel in a sealed box. There's a thread here on the adjustment procedure
TripleB
TripleB
21,078
183,283
Caryville, Tennessee
X2
rickoshea
i had the same issue.turned out to be the cable adjustment,not the rear cable under the floor that adjusts the turf mode.mine was way out,only thing is now it doesn't shift as easily into low gear like it used to.
Capitan
20
27
Friant, CA
I want to thank everyone for your suggestions. I called the dealer and he said, I'll pick it up and take a look see. He called me and explained an electric module which sends a message to the digital display had a short. He ordered the new module and will install and delivery the unit back to me. Extremely high in customer service. So pleased with him. Of course hes buttering me up to purchase more from him. Hes winning, I'll be back.
