I am trying to keep away from mounting lights etc to windshield so if I want to take it out no big deal. I don't mind at all running with no windshield in the summer!!Yep
Waiting on a good flip out glass windshield or may need to make one.
There is an adjustment screw under the headlights, it helped mine a ton with that problem lowering them down a bit.Good Night Nurse! Did a coon hunter design the high beam lights? I was running around the mountain last night after dark for the first time in the machine, and while enjoying the stealth mode afforded by the full moon, I decided to try out the headlights. Low beams were pretty decent, but the high beams were shining up into the top of the trees. I couldn't tell if they provided more down the road distance or not, but could see to the tops of the trees, where I try NOT to drive.
Impatiently waiting the arrival of the last of the parts I need to mount a decent light bar.
crazy how I've heard this several times adjusted way to high lol mine just happened to be perfect!!!There is an adjustment screw under the headlights, it helped mine a ton with that problem lowering them down a bit.
Yes, I was mounting the 20 inch light bar to the front bumper yesterday and saw the access hole for the screws there. Figured that was what they were for. Just need to drive it again after dark and have the right tools with me.There is an adjustment screw under the headlights, it helped mine a ton with that problem lowering them down a bit.
what is the wattage output of the 1k?Mine was 50 but will be going 52. Watch the wattage
How did you bring the wiring into the cab? After reading this post I just order one.
Thanks that is how i had planned to do it . The one pic looked as if you just ran it over the visor and above the window molding.Drill a hole and use a rubber grommet to stop the water from dripping to your leg
wow, that is a sweet light setup! nice work on the 521"
