P1000 Lightbars
Scooterchris
No longer active.
Dec 25, 2015
396
237
with the light bar up that high how much glare did u get from it. im worried about mounting one and being blinded by the light reflecting off the hood
Yeah definitely no glare at all
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
I went with this Penton mounted to the black plastic between the hood and windshield. Not hooked up yet, so not sure whether I will like it here or not.
Peton Light Bar
20160116 152810
HivoltageHonda
HivoltageHonda
374
367
Hernando, MS
I thought about doing my 42" curved like this one since that's about the only place. Or I thought bought selling and get the 32" and put it on the black peice on the hood.
ghost
ghost
993
1,873
BC
its straight. fit in there like a glove!
Did you mount on the plastic? I was gonna try the same thing but not sure if it solid enough.
You happy with the location ?
franzw
franzw
277
249
pacific nothwest
The bigger bars have a wide throw or add the small cubes.
I'll probably just have a single 40ish inch bar.
Here is where I mounted mine. Ran power thru isloated 2nd battery source. Have 2 more for rear light. On dash with toggle switch. All go on same time while off roading.
E57e0386ce06fc6ab3f0a26a9a0d0db5
A bit overkill.
100 0954
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
I'm completely happy with the location. It's mounted in the black plastic between the red plastic and the windshield. Very solid. The thing I like the most is that its in a relatively protected area and I don't have to worry too much about limbs and stuff taking it out.
ghost
ghost
993
1,873
BC
Got my 32" curved bar installed - finally.
Whats great about this mounting location is branch protection.
It was bumping the windshield frame so I shimmed it up 3/8 inch.
IMG 2387 IMG 2388
Reactions: Tot and PioneerPete
ghost
ghost
993
1,873
BC
The light is amazing.
3 sets of images from 2 locations: Low Beam, Hondas famous tree-top high beam and just the light bar.
I had pictures of lights bar with high beam but not much different tha just the lightbar.
IMG 2390 IMG 2391 IMG 2392
IMG 2397 IMG 2398 IMG 2400
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
ghost
ghost
993
1,873
BC
It doesn't technically need one but It's on a relay.
It's 180W
mtaa12
21
22
A bit overkill.
How is that light bar doing mounted to the top like you have it? I just bought a 50 in curved and that's where it looks the best. I was just a little hesitant.
My 700 has been gone almost a year now, it wasn't going anywhere and I hit plenty a limb with it.
Bbd3b4aa79c4ecc195a5553618f2f885
T
TheBob
58
57
North West Arkansas
Good Night Nurse! Did a coon hunter design the high beam lights? I was running around the mountain last night after dark for the first time in the machine, and while enjoying the stealth mode afforded by the full moon, I decided to try out the headlights. Low beams were pretty decent, but the high beams were shining up into the top of the trees. I couldn't tell if they provided more down the road distance or not, but could see to the tops of the trees, where I try NOT to drive.
Impatiently waiting the arrival of the last of the parts I need to mount a decent light bar.
dale5740
dale5740
886
417
mt airy md
I assume that u keep your front windshield on all summer? doesn't it get hot?
