russknight
Anybody running them? If so, where's the best place to buy them?
Right here in Florida. Thanks!Check out this company. The make AGM and lithium. But make sure to look at batteries of the page I'm linking, they're for auto but there small and light weight. https://braillebattery.com/collections/performance-auto
Glad I could help out. I'm looking at one for a second battery myself. Little pricey but normally you get what you pay for.Right here in Florida. Thanks!
But double check the specs on their batteries to be sure they meet your needs. Are you after a battery for cranking the motor, the main battery? That wants to be rated for cranking amps (CCA, or cold cranking amps measured over a very short term, like 30 seconds). If you are after a battery for Aux, running accessories, then you probably need a battery with thicker plates (deep cycle) and a higher amp hour rating, where CCA is not important, but the ability to deliver decent current rates for longer periods is.Check out this company. The make AGM and lithium. But make sure to look at batteries of the page I'm linking, they're for auto but there small and light weight. https://braillebattery.com/collections/performance-auto
My opinion…Glad I could help out. I'm looking at one for a second battery myself. Little pricey but normally you get what you pay for.
My opinion…
When it comes to lithium batteries, you’re not really getting what you pay for.
They’ve come a long way in the last decade, but still way over priced.
I have some I use for flying model airplanes, they pack a good short duration punch. But for amp hour capacity they’re really not mature technology yet.
What you’re paying for is the continuing R&D needed for the next generation of wunder battery.
Lead Acid technology is mature. They’re not going to get much better than what we have now. If you take care of LA batteries they are reliable and perform well.
Sitting discharged is the big killer of LA batteries. Keep them fully charged with a smart trickle charger and they will usually last a long time.
I looked at their site . . . couldn't find anything about whether they have an on-board BMS or require a separate battery charger (if they use a regular charger, then the BMS should be built in, I'd think). I'd be cautious without more info - maybe I'm not looking in the right place.This is the one I bought, half the weight of the original battery. 6 months in and zero problems. I bought it on the internet.
I never questioned it. The Pioneer alternator seems to keep it fully charged so I would think a standard charger would work. Hopefully I never discharge it that far. Ignorance is bliss I guess.I looked at their site . . . couldn't find anything about whether they have an on-board BMS or require a separate battery charger (if they use a regular charger, then the BMS should be built in, I'd think). I'd be cautious without more info - maybe I'm not looking in the right place.
Well if it catches on fire it will be an excellent opportunity to try out my new Element Fire Extinguisher! 😂I'm no expert. Discharging isn't the problem. The battery management system (BMS) monitors each cell individually to keep state of charge between cells the same, this prevents a stronger cell from being overcharged while another weaker cell is undercharged - without a BMS, that spread between cell voltage widens and bad things can happen. The BMS typically also guards against overcurrent, overvoltage, overtemperature, etc. So good for both safety and long life.
Probably not much risk, though water is not effective on lithium fires - urine might be! Word of caution never pee on a high voltage electrical fire. Well, unless you've a lot of practice peeing on electric fences and such, and/or have built up a degree of stamina. If the occasion warrants, and you really have no other choice, my strong suggestion is to pee in spurts. That way the electricity cannot quite reach your hose "nozzle" end.I say just pee on it but I'm older now and my hose pressure is down.
I’m glad it’s working for you. Don’t get stuck.This is the one I bought, half the weight of the original battery. 6 months in and zero problems. I bought it on the internet.
Everything you said is true, except the discharge to 0% thing. Maybe to the BMS cutoff, but not 0%. LiPo batteries are damaged below 20%. I think LiFePO4 may be as well, but usually have a BMS to stop discharge. And you can’t charge them when it’s cold.I respectfully disagree with some of what you've said.
Lead acid (Pb) batteries last longest when discharged only down to 80%, and 50% should be considered the "floor" for longevity. They last longest if stored fully charged. The plates will sulfate, increasing internal resistance and capacity if left discharged for any length of time. Their cyclic life is limited compared to Li or LiFePO4.
On the other hand "lithium" batteries should be stored a 40 to 60% charge for optimal lifespan. You can discharge a lithium battery down to 0 percent with no damage. Unlike a Pb battery, Li maintains its voltage much better during discharge, and charge/discharge cycles are far higher than Pb. So while initial cost is higher, the additional life cycles makes up for that. Energy density is much greater to, especially considering the lighter weight.
Not saying Pb doesn't have it's place - - boringly reliable. If you have a Tesla, you never know when it might be good time to stop and have a nice campfire.
Depends, not the diaper, on how tall the fire is. That battery is way on up there in the scheme of things!I say just pee on it but I'm older now and my hose pressure is down.
The element is powder free and never needs recharging. Very light weight too.Probably not much risk, though water is not effective on lithium fires - urine might be! Word of caution never pee on a high voltage electrical fire. Well, unless you've a lot of practice peeing on electric fences and such, and/or have built up a degree of stamina. If the occasion warrants, and you really have no other choice, my strong suggestion is to pee in spurts. That way the electricity cannot quite reach your hose "nozzle" end.
