P1000 Looking for ideas ....
BrotherNov
122
281
Springfield, IL
I like to keep my stuff on battery tenders. I'm still in the "initial modifications" process of ownership, and I'm trying to figure out a more "elegant" way of plugging my tender into my buggy. Right now I have to take the hood off. I purchased a 6' extension thinking I'd just zip-tie it to the grill. It would be ideal to run it through the dash, but I'd like to avoid just having 3-4" inches of wire dangling out. Has anyone run into a dash mounted receptical the tender would plug directly into? Better ideas?
IMG 0434
105,595
and here I was hoping you were talking about spacial vacuum evaporator weapons and pulse cannon mounts. Dang, disappointed again!
Dirtstiffs-1000
Dirtstiffs-1000
1,672
6,082
hondasxs.com
20200529 172009
This is my approach. Single plug for each battery.
They can be tied together for more amperage and starting power. They can be used to jump the 2nd battery to the OEM. And either plug could be used for a power port and even jump start others.
OCD, probably.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I
OCD, probably.
I used a plug like this on my dash but one plug charges both batteries. Works great.
Reactions: Hondoman
G
Grayday
7
Tucson
These might be what you want on Amazon
Electop-SAE Quick Connect Solar Panel Mount Universal Flush-Mountable Connector, 12AWG SAE Cable with 8 Screws for Solar Generator Battery Charger (2 Pack)
Reactions: Papaandhistoys
Hondoman
Hondoman
727
1,697
Texas
I
This is what I did, added one port on the drivers side of the dash.
rickoshea
for my truck camper i used remote battery jumper posts.you can mount them anywhere.
DAV11
DAV11
105
194
Minnesota
I just leave mine sticking out the top of the hood by the windshield.
20200602 184957
Rubin
Rubin
45
170
Canada
I wanted to hide my plug so I went this way don’t even think about it anymore charges both batterys because its hooked up to my main battery threw a voltage sensitive relay module to my second battery. When the first one is fully changed it automatically starts charging the second battery.
Image Image
5,492
25,270
I use that same connector only I have it mounted right above my hood, below my windshield, right in the center. You can see it in the picture. It works well, don't have to take the hood off to plug or unplug, you can see it easily (so you don't drive off with it plugged in). Works good.
Motorhomes use panel mount SAE plugs for portable solar panels, similar to the one above. Oops, already covered in post 5.
Reactions: bcourv99
