P1000 Low Range, auto shift from 1st to second?
GRANITE
GRANITE
People Dying to come see me!
1,100
5,550
Brookville, Indiana
Loving the 1k3 but trying to figure out the bucking issue while working it around the house. IF I'm in low and I take off I do fine with throttle control until it shifts out of first gear and then I get the "bucking" and not sure if there is a problem or what can remedy it. Help?
has it warmed up and does it have the clutch update?
Reactions: BWAF
GRANITE
GRANITE
1,100
5,550
Brookville, Indiana
Its a 2018
its a 2018 and I was told all the clutch update were done. Maybe I'm not letting it warm up enough, i don't know. Maybe leaving it in manual gear and making it stay in first gear is the best option
Reactions: BWAF
If I am working it around the house It has to get warmed up before I can creep and it not jerk some, I noticed it jerks more in Low range initially than High if its not warmed up.
Reactions: GRANITE and BWAF
popeye
popeye
3,275
14,644
kapowsin, Wa
Its a 2018
most rigs pre clutch update,16-17 the take offs would smooth outon the machines after the first 100-150 miles or first service. not sure if the 18s will do the same?
69,050
I was going to say the same thing. I use manual for creeping. Auto low for mud holes she drops into 2nd with authority and pulls
GRANITE
GRANITE
1,100
5,550
Brookville, Indiana
This beast is a lot different than the little p5. It gonna take some getting use to! When you all were trail riding ie..on way to top of the world, do you run it in low manual?
Reactions: BWAF and Plumber32
69,050
Low manual yes. Usually 3rd -5th.
Reactions: BWAF
RyanG
25
12
NORTH BAY
Did you ever figure it out. I believe im having same issues as you. I put it in low gear and sounds like clunking noise when i start to get on the throttle. Awful sound.
