Talon Maxxis Carnivore 29x9.5-15?
bjniceguy
322
431
Iowa
did you ever get pictures? also how does he like them on it?
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
anyone else running these on an X with stock wheels? Mine should be here tomorrow
U
UPSMAN
16
North Carolina
I have them on stock wheels,seem fine,only problem you will need wheel spacers to do a tire rotation for them to wear even
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
I thought stock wheels had different offsets already front to back so spacers wouldnt be needed? guess wrong assumption
U
UPSMAN
16
North Carolina
yes you are rite about offset but when you rotate tires ,(front tire to back) then the offset is way off on the back when the tire's offset was made to run on the front not the back from the factory
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
ah, yea. Hopefully by the time i need to rotate i can afford wheels and get the same all the way around at that point, and add spacers to the rear
