P500 Maxxis zilla 28”
Mason89
Ontario
Hello all,
I just purchased maxxis zilla 28x9x14 and 28x11x14 for my Honda pioneer 520, has anyone been able to put this size of tire on there machine and not make any mods to it? I has seen people with 30” tires and said they had no mods.
looking forward to hear back from everyone
The Green Goat
The Green Goat
2,399
17,682
Hello all,
Depends on the true size of them and your wheel offset.
I'm running 27x10x14 on all corners and I have some slight rubbing on the fender well in the front (I don't think the 500s have this plastic piece).
My tires true size is 26.25x10". I plan on running 1.5" spacers up front which I think will cure my issue.
Splorin
320
904
Maine
Tire rub or not rub is all over the place. When I temp run my 28x10x12 MudLites on 4-3's which measure 26.75 loaded I rub my unmodded frame rail hard and notice a clean spot on footwell fender. Then again there's 30's out there that supposedly don't rub so who knows.....
194,663
I never even noticed it until I hooked up the plow. Under some compression, wheel turned full left and in reverse. Wasn't just a rub either, it was grabbing and actually bent it down a little bit.
Reactions: Backwoods
Splorin
320
904
Maine
Mason89, your rim choice and their offset will have some effect but I think you'll be fine. May need some massaging to make 'em work. Report back on how they work for ya.
116,565
Howd they fit
The OP hasnt been on since 2 days after he started the thread over 9 months ago and no pics or feedback. So I doubt you'll get an answer.
Speaking of pics 😜
Welcome first time poster to the forum.
What machine do u have, year and miles?
also we have unwritten requirement for your machine its called
Pics Or It Didnt Happen!
Dont be like the OP 🤨
