Had a moose plow on my previous atv -just bought the mounting plate for my 17-p500. Had a brake line in the way of the u bolt at the rear on drivers side. Had the floor in the way on pass side. Ultimately got the plate mounted but it was not easy.
Yes mod mount! I agree was trying to repurpose the plow and push bar should have bought the quick attchSo it's a midmount? I had one on an atv and used it for ten years. It got the job done but now having a front mount is so much nicer. Allows you to lift the blade higher and stack your piles. Having the winch to lift it as opposed to manual is a bonus too.
Yes mid
You will also likely need to swap the push tube assembly out if you switch to a front mount setup. Not hard, just a few more bolts to pull and reinstall. Front is the way to go on a SXS though for sure in my opinionThanks Shadesmn. Think I will take it off and return it tomorrow. Not worth the trouble.
I still have the stock tires and rims so clearance Is a factor.
So my local dealer would not take the moose mount back because I tried to put it on. Nice service as I was going to purchase the rm4 system. Currently shopping elsewhere.Thanks Shadesmn. Think I will take it off and return it tomorrow. Not worth the trouble.
