Mounting skidplates
BigOL3
BigOL3
2,997
8,921
Just curious as to what techniques yall have been using to lean the P1Ks on its side in order to attach the skidplates?
I was thinking of using the frontend loader on the tractor to slightly pick up and pull back until it was laid over on some blocks on drivers side .... hopefully not fall completely on it side, but rather kept at about 20-30 degrees.
Any better ideas, for a ONE man operation?
Reactions: Plumber32 and BWAF
BWAF
BWAF
I get paid to pass gas
8,869
42,496
Carthage MO
Not too scary F36db58994e4f9b54851559cf5146be3
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,543
Central Iowa
I had the front on car ramps then used a Jack to lift the full skid against the bottom
Reactions: BigOL3 and BWAF
BigOL3
BigOL3
2,997
8,921
I may have to try it the conventional way. Was hoping it would be easier to get to/hold in place/attach, on it's side, as Trail Armor does it. May need to forgo that idea. Also was concern about fluids being leaned waaaaay over, being possible problem.
Reactions: BWAF
Mtnman
17
12
maryville Tennessee
I used my winch and a tree limb
Reactions: BWAF
P
PolkaJoe
90
103
NEPA
I just drove mine up pickup ramps, the only thing I couldn’t get in was the last 2 rows of bolts on the aft end .... but the plate stayed in place from the other bolts. Once I backed it down to level I put in the others.
Total trail armor install time; 1 hour 15 minutes which included a cup of coffee half way through.
70,273
I just slid under mine. Used a car jack to hold the skid in place 2 screws in it and pull the jack out.
Reactions: trigger and BWAF
Definitely is the easy way. My concern was a cable breaking or hydraulics failing. Guess I could come back with a 'double safety' option.
I didn't leave it on the line.. it’s resting on the rear cage. I had to push it to get the front to drop back down.
