P1000 Mudbuster Front and XL Rear
Jensenj71
Jensenj71
47
107
Meridian, Idaho
Ordered Mudbusters on Wednesday and they arrived Saturday. I was installing new tires and wheels and took the opportunity to install the Mudbusters. Great instructions and took about 2hrs while on 2 post lift with tires off. Good coverage and they should definitely keep the mud off.
19970
19972
69,282
I just went the same route. Great product.
Firemedic530
Firemedic530
387
1,133
West Jefferson, Ohio
I installed mine last week. My only concerns are how well they will flex when rubbing trees and when dropping into a ravine.
I'm also going to add a brace to the back piece behind the rops bar. I don't think the 1 little screw is enough there.
Hondoman
Hondoman
727
1,697
Texas
Ordered mine on the bf sale, and they are sitting in my garage waiting to be installed. I keep my pioneer at my hunting lease during deer season. After shes home and had a good bath I will install the mudbusters. Its covered in mud now.
Looking forward to it because mine slings mud bad.
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
I have no interest in these but if that's your thing, cool
Reactions: sharp
Il’l probably put mine on tomorrow.. with spacers and wheels they’re very much needed!
They work REALLY well even with spacers and wheels. Mine is 68” wide and the only place the mud gets through is the hole around the rear ROPS. That lets a LOT of mud through all the way to the roof. I guess I will steal @joeymt33 filler idea today finally.
We had 2” of rain in the last 24hours so it was good and muddy and it rained the whole time so some got washed off. But you can see where the gap around the ROPS made a big difference in how much mud was on the machine.
89011E44 1E85 4B4D BB2C BE258D80E8A3
F1B23131 4E33 4253 A2AB 060F92096A9D
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
They aren’t the best looking but they work well keeping the mud off of you and out of the cab.
I’m not a bogger but if the trail is wet mud is flying.
That's my problem, they look so out of place that I probably wouldn't appreciate how they work. I also don't think the mud is that bad
dnjones161
dnjones161
583
1,713
Ohio
I'm with you in the look @ToddACimer. I had them in the cart on black Friday but couldn't bring myself to pull the plug. I'm running a little bigger tire, but factory wheels, so the mud on the sides isnt too hateful. It's been SUPER sloppy with rain in Ohio the last month though, so in my daily deer-feeding run the machine (and garage) have become quite caked with mud under the rear. There are soo many crevices under, it takes foreverrr to clean it out. I think a set would be nice for easy clean up and keeping mud out of the footwells (I use for storage on longer rides), so I'm going to try to fab up a version that doesn't stick out quite as far. $35 for a 4'x8' sheet of 1/8 inch HDPE at Menards, I figure I should be able to come up with something pretty elementary that will fit my needs and not stick way out under the rear. Mounting is really the only question mark, as i haven't been able to find a thread that documents the mudbuster install very well.
I'll be sure to take lots of pictures and document it when I get around to figuring it out.
I’m with you, cracks and crevices in the 5 seater are a pain. I made the original for the 700 it was a pain and time consuming. Then about 2 months after I made mine mudbuster started selling some, I just bought mud busters this go around.
I want to be not frozen, mostly dry, and decently clean. For the most part I don’t care how it looks to accomplish that. I’ve gotten to a point in life where I give zero f***s and want to be comfortable, I gave up proving things to people and wanting their approval a long time ago.
My goal now is to help others accomplish the same.
dnjones161
dnjones161
583
1,713
Ohio
Oh not too concerned with what anyone else thinks about it, just doesn't quite please my eyeballs. I've gotten a kick out of working on my own little projects anyhow.
I think I've seen your build on those...remind me, did you bend yours with a heat gun or a blow torch? I have read both, and I don't have the heat gun so I'm tempted to try the torch first, but I don't want to completely cook my plastic either.
Ragnar406
Ragnar406
The Great Bald One
4,450
17,035
Bella Vista, AR
@JTW without mudbusters and @Plumber32 with - same trails so you can see a difference ... notice JTW’s mid panel and gear in back of his ride
7347CFA7 A7D6 410A 8B52 4BCAB9C94F05
My wife went on a ride after I had just added aftermarket wheels and I happened to receive mudbusters on father’s day a few weeks later ...
69,282
And mine were only the dinky ones on the rear. I'm now full coverage all around. They make a yuge difference.
69,282
Thanks to you I care about nothing any longer. Thanks ....
