P500 My Dash Switch Locations + Voltmeter
L
Lburou
55
147
Dallas/Fort Worth area, USA
We are adding a light bar & rock lights to our p500. We also relocated the headlight switch and put the new voltmeter in its place. Here are the pictures of the dash modifications. One picture illustrates the way potential switch positions are outlined on the back side of the dash, making it easier to locate as many as four additional switches.
IMG 3280
IMG 3282 LI
DoubleDee
DoubleDee
21
32
Dallas, GA
Nice. Hadn’t thought about moving the headlamp switch. Like the uniformity with all the lights in one area. And using the existing hole for the voltmeter. Im planning my layout and will use this as a template. Thanks for sharing.
Reactions: Lburou
70Bones
70Bones
888
3,779
New Brunswick Canada
I can't see my headlight switch when driving, it's hidden behind the steering wheel... might not be a good idea to put something there you would like to see often...
Reactions: Lburou
L
Lburou
55
147
I used a dremel tool to enlarge the original hole for the headlight switch. These particular switches will be illuminated whenever the ignition is on.
bowhunterbill
bowhunterbill
413
1,271
Bozeman, MT
Nice work. I second the comment about not being able to see the headlight switch on the dash.
Reactions: Lburou
34,174
Even the triangular space to the left and right of the digital display is useful for mounting.. In the one on the right I have a dual USB if you look behind the Ram mount for phone..
87292F61 80E4 4183 94A6 D296110AD72B
Reactions: 12luck12 and Lburou
L
Lburou
55
147
12Luvk12, I'd be interested in just how you mounted your rock lights. Do you have any pictures? How did you route the wires? Where did you find that rear carrier? Any more pictures of it? TIA :)
Todd627
Todd627
56,241
614,719
MI
X3 👍🏼
12luck12
12luck12
95
371
53
Genesee idaho
Home Built the back end. Will try and get some pics of the lights i used. nothing special bought off Ebay.
Reactions: Lburou
