Yesterday I got a good start on my dual battery setup. I am doing it similar to "nc dragon" on youtube. I'm holding off wiring up all the switches and accessories until my switch panel comes in.
I go from primary battery to isolator to second battery to winch to relay to fuse panel. I plan to run the ssv stereo, front light bar and rear light bar off the fuse block.
I'm also planning on using the same radiator hose to extend my intake as ncdragon used. I used the factory setup for the winch which is why my power block is mounted where it is.
