P1000 Named Best Utility UTVs of 2016 - Honda Pioneer 1000LE
66,870
Pioneer
ATV.com has named the Honda Pioneer 1000-5 LE the Utility UTV of 2016!
Source - Best ATVs and UTVs of 2016 - ATV.com
Late in the year Honda released its Pioneer 1000 Limited Edition with I-4X4 and Hill Start Assist (HSA). These features help the novice or moderately experienced drivers execute terrain like a horse thief in the late 1800s. It is swift engagement of differential lock as the onboard computer sees a need instead of requiring the driver to stop and twist a knob. The usefulness of HSA makes a stall on an incline become worry-free for novice drivers as the brakes are applied via the brain of this Honda Pioneer and gradually released as you begin to accelerate. This is just the start for a new tomorrow in the world of UTV.
Full Frist Ride Review around a simple dirt track is here --> 2017 Honda Pioneer 1000-5 Limited Edition Review
BUT dont read into that too much. We are still awaiting a REAL REVIEW of the new I-4WD system. Hope to see one out before Spring!
Full BEST of 2016 listing:
Sport UTV of 2016 - Can-Am Maverick X3 X rs
Utility UTV of 2016 - Honda Pioneer 1000-5 LE
ATV of 2016 - Polaris Sportsman XP 1000
Jediwrathchild
Jediwrathchild
212
410
Kodiak, AK
Their review talks about thicker seat foam. I wonder If that's a seat heat solver.
Reactions: Ginger
208,726
After reading the review, sounds like all I need is shocks.
Dasmoeturhead
From what I read in the UTV Action magazine my 2016 suits me just fine. I don't need no stinking computer to shift in and out of 4wd for me. I like to have a little control. That's 4 wheeling. I do like the switches, and shocks though. The thicker seat?, mines just fine. JMHO
208,726
I feel the same, Honda dosen't have the bugs worked out of the 16s
HondaTech
Tbh if the seat is a heat solver then it will most likely fit the 16 model. Other than the I-4wd, brake features and lighted switches any 16 could be made into a 17 LE. But no one wants the Honda bumper, skid plates, A-arm guards for the money. Any customer units i work on always have aftermarket ones instead.
Reactions: CumminsPusher
322,690
I know it's a longshot but in your opinion could mode memory be swapped?
Reactions: sharp
HondaTech
I'm not 100% sure how it operates. Some places have said its only after having put the machine into reverse that it remembemuch thars the mode. It's probably just in the programming on the ecm. If that is the case then it should be a simple swap to see if it works. In our diagnostic tester program there's a ecm update/flash option. We've never been able to use it yet, but maybe this could be a use for that feature. I cant see it being very much that would allow you to hold the mode.
322,690
That's a much more positive response then I had figured. Well hopefully and thank you!
Reactions: sharp
Elkhunter
Elkhunter
345
453
Minnesota
So' what did Dirt Wheels have to say about the 1000LE?
GPR1500SC
GPR1500SC
861
2,425
North East MO
  2. Talon X LV
Alien Tech software is the real deal but to expensive just to play with roughly $15,000. to get setup in for class 8 truck tuning, it would be able to make the change you want if the user is capable.
KESS v2 lo strumento per la rimappatura dei veicoli
G
Ginger
Jolo WV
I joined this forum to see if anyone else complained about how hot the seat gets.... took my granddaughter for a short ride.... seat got so hot I thought it was going to burn her.... very uncomfortable
Reactions: BLC
ghost
ghost
993
1,873
BC
yes - you'll find plenty of info (and b****ing) about that. I'm one of them.
Fortunately there are some fairly easy fixes but it's bizarre that Honda has not dealt with it properly.
Search the site for Heat Shield and Bilge Fan.
Once you get past that you'll be a lot happier. At least I was... Installed both heat shield and fan and it much better. And as a bonus turn the fan off in the winter for some welcome butt heat.
Reactions: Jshell3 and Ginger
