P700 Need help installing high lifter lift kit
V
Vizsla22
Oil City
I have a pioneer 700 deluxe. When I try to install the front bracket for my high lifter kit my headlight impedes the bracket from going in straight. Any help is appreciated.
20923FF7 D424 4E43 B134 F36413ABC720
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
View attachment 175045 I have a pioneer 700 deluxe. When I try to install the front bracket for my high lifter kit my headlight impedes the bracket from going in straight. Any help is appreciated.
everyone iv ever seen put it on a newer bike had to trim the headlight housing
Russ989
Russ989
22,645
147,291
I was just getting ready to tag you and yet here you are. Good man
Reactions: Alan_Vander
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
i didnt put this one on. just read up alot about it. for the price of the 2.5 highlifter you can put 5 inches and buy a set of lights.
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
Instead of trimming. can you take a heat gun to it and shape it IN some.
is that with all models? just curious cause isnt the 17+ headlight housings bigger?
68,241
I forget what year. but around then they upgrade the housing so the Pioneer 1000 LED lights would fit without modificatin.
V
Vizsla22
Oil City
Is there a better option than the high lifter 2.5?
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
i think its 17 cause iv seen alot of post on the fb page talking about the upgraded light bulbs.
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
strongmade has 2.5 for like 120$. they make spring spacers that are from 1.5-3 inches for about 20-25 bucks. string made relocates the bottom of the shock instead of the top.
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
i wouldnt call 1 better than the other. they all do just about the same thing. the spring spacer will give it a little better ride than the other 2. but the strong made bottom relocate us the easiest to put on.
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
With the 2017 and newer 700 models, you'll need spring spacers to avoid hitting the back of the headlights. They make it ride a little better too. Here's a link to ours if you're interested. Honda Pioneer 700 2" Lift Kit
wait what?the shock or the tire hit the back of the headlight?
SuperATV
SuperATV
1,716
12,586
Madison, IN
www.superatv.com
I'm pretty sure the lift bracket contacts the back of the headlight, but I guess it could also be part of the shock during travel. Pretty sure its just some interference with the bracket though. That's why we went to the spring spacer with the 2017+ models.
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
kind threw me off for a sec. was like if the shock going to hit its going to hit with spacer or not. not sure why they even make the top ones like that. unless strong made held all the patents for the bottom. when i got my lift. strong made and wheel spacers from a rincon were the only thing offered.
Reactions: SuperATV
