P1000 Need help wiring warn provantage 4500 rocker switch
Scout19
Scout19
54
114
Princeton
I see on the honda sxs store there is a pre wired rocker switch. Has anyone wired that to the warn provantage 4500 that Honda puts in? I cant find any info on where to connect the rocker switch to.
64,008
It has a common contactor box right?
If so. It wires like all other winches.
Just need to know if the wires are spade connectors or bullet connectors. Im talking about the small wires.
If you can snap a few pics i can tell you exactly what to order.
Thanks.
Reactions: TripleB
64,008
Found this.
It uses spade connectors.
But also has bullet tails it looks likes.
So which ever you used.
To install. Just hook the green wire and black wire to the correct spade.
Then apply 12v + ground to the red and green wire on the switch. Recomend a key-on source. 3c68360e3b65d30bbe1dd957a0f497e0
Reactions: sharp and TripleB
Spoonbill
Spoonbill
213
262
East TN
It will depend on the number of connections on the back of the switch which determines the location. There are many videos on You tube to get a good idea....
