P700 Need help.
L
LesSwain
6
Alabama
I have a 2016 700-4. I recently had the valves adjusted cause I was getting a little noise. Since then I'm having trouble with it shifting and it seems like it is hitting a rev limiter at speeds anywhere from 8-20 mph. Any advice would be appreciated. Thanks in advance
Reactions: Russ989
Russ989
Russ989
22,565
146,496
Did it start after you had the valves adjusted? If so, you need to take it back and tell them it’s not right.
Reactions: Backwoods
Backwoods
Backwoods
32,142
330,154
Douglasville ga
I agree take it back. Plus you still may have some warranty left . Let them worry with it.
Reactions: Russ989
L
LesSwain
6
Alabama
It was an individual but it was acting up before hand just seems worse now. Had to tow it in lastnight
Russ989
Russ989
22,565
146,496
Check your oil using this procedure and tell me what the oil level is.
E115925E DE36 40BA 9205 BC23A427FDB6
L
LesSwain
6
Alabama
It was low. Which didn't make since because I had recently changed the oil, but after I handed oil it shifted a little better but then noticed a little smoke when I was taking off and now you can smell burnt oil also
Reactions: Russ989
Russ989
Russ989
22,565
146,496
You need to pull the spark arrester out and make sure it’s clean. Check to make sure your spark plugs aren’t loose and then it’s time to check compression. Did you over fill it by chance?
L
LesSwain
6
Alabama
No sir I haven't
Russ989
Russ989
22,565
146,496
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
have to badly over fill it. cause i run 3.5 quarts in my bike. have since day 1 back in February 2014. lol . check spark arrestor. if you let it go too long before adjusting valves you could need valve seals. which would explain low oil and smoke.
