G
Big tires mean bigger mud guards, looking for something good but not too expensive, seen kemimota had a set for 120 anyone used? Or do I need to pony up to the mudbusters? Advice please
Online at :
SpeedwayMotors.com
Airdam/Body extention Plastic
1/8in Thick x 22in. Wide x 25ft. Long roll. SMOOTH texture
Black was under $75.00 shipped to door ( guarantees 2 Day Del. )
Other Colors & lengths available.( $$$$ varies)
Durable & Flexable -- stiff enough to hold desired shape using a heat gun.
Easy to work with -- Heat Gun -- tin snips & or sabersaw.
Only your imagination & fabricaton skills is holding you back.
Mud Guards
Fender Flair's
P520 Box area above & in front of Rear Tires (prevent mud build-up up )
P500 Floor protcctors ( P700 too )
Unlimited uses! Atv/UTV-- trailer -- Truck
LESS -- $$$$ than 1 set flairs or mud guards
View attachment 322476 View attachment 322478
Which ones you recommendPony up!
Do it once, pay once unless your planning on making your own, thats fun 🤣
U use the extended ones?Mudbusters are worth the $ if u plan on keeping your ride long term. I've tried others in the past and I'm super glad to have MBs on my x4 now!
I made mine from this same material except I bought it from a local speed shop and did not half to buy such a large quanity. I made a pattern out of stiff rigid paper and made changes I wanted and traced it out on the plastic. Only down side the plastic is a little flexible out on the end in the back but if I clip a tree it does not break but just bends out of the way. I even plugged the simulated air vents on the upper side towards the back so they do not fill up with mud and I made inner fender liners for the rear in front to the back tires where the open cavity is. Took a little time making it but enjoyable time spent in the shop with my buggy Total cost about 25 or 30 bucks.If your going ( DYI ) method check Out attached post::
I sure do. Great investment in my opinion.U use the extended ones?
Mud busters, they saved my ass from getting mud shot down my neck.Which ones you recommend
How you figure?Yours are the standard ones, they look pretty good but not sure if they would keep the mud out of mine
And?Mud busters, they saved my ass from getting mud shot down my neck.
My machine is 68in. With new tire set up, standard might work fine, I don't know?How you figure?
got any pics as to why?
just got with the XL’s then
I see yours is cabbed in, how did you see those large holes in back of doors
I didn’t I put in the inferno heater. it works great in the 2 seaterI see yours is cabbed in, how did you see those large holes in back of doors
