P1000m5 New 2022 heater kit issues
K
KSN1495
14
Campbell
I wonder if they didn't line the blower motor up with the ducting all the way.
Is a dual battery required for the heater kit? I don’t have that and now my heater runs for a max of 20 mins before completely shutting off
K
KSN1495
14
Campbell
It’s going back to the dealer this Thursday and better be resolved or I’m filing a complaint. This is complete bulls*** as I have no heat in the winter. I’m guessing the people working at my local dealer are incompetent
  • Wow
Honda hasn't specified a dual battery since the Big Red winch kit.
Reactions: Hawk53
So I start the machine up this morning and it seems to be working fine. It only quits working after you drive for miles, is the blower motor over heating? Is the outside air temp (32 degrees) affecting something? This is also the bracket job the dealer did because Honda doesn’t have a proper bracket from their own products to mate up with the defroster vent! Why is Honda so far behind on this stuff
Also that bracket is bulls***.
Your given a bolt to attach the bracket shown to the windshield. They mounted the vent and didnt line it up with the bracket/windshield first. Your dealer is a bunch of hacks.
Ohio4x4
Ohio4x4
I brought the dishwasher
1,459
14,671
I'm guessing this guy's onto something. I don't have a heater and run the Honda soft doors. I've spent some time sealing up the large air leaks and with the fan motor inspection door off I plow snow in a hoody. As for the intermittent issue we had Ford vans at work between 08 and 2012. They would have the resistor get hot damage the switch and motor windings. Until it was all replaced at the same time along with the damaged mulex plugs the problem would continue. We never found a route cause but something in the oe set up took out the rest of the circuit. This was an issue on 20ish vans. One of mine actually had the blower speed switch glowing and melting.
  • Wow
NorthernJoe
NorthernJoe
320
1,213
Northern Ontario
Like I said earlier, My heater works great! the cab stays warm, not hot. The defroster keeps the windshield clear. I do not have a dual battery. The heater will run for hours without issue. This heater is a great improvement over the Honda heater that I had in my 700-4
Reactions: KSN1495
Hawk53
Hawk53
461
587
Alberta Canada
It’s a Honda kit, it’s okay but not great. I have the fabric surround but if it’s windy, outside air can overtake it. My blower motor also shuts off periodically then comes back on. It’s quite annoying and I want Honda to fix this issue, currently they cannot figure out what’s going on.
Did your intermittent heater blower issue get resolved and if so what was it?
Hawk53
Hawk53
461
587
Alberta Canada
Well, that's Ford for ya.;)
Techman1961
Halifax
I’m thinking the dealer messed something up. They were really behind figuring the newer heater unit out and I was told someone quit over the frustration…both units quit working after the machine has been running for a bit, like some resistor is overheating or something. Later today I’m going for a ride to try to mimic what happened yesterday.
Anyone know where I can buy parts for oem under hood cab heater . Resistor box on front of heater. 6 wire
Techman1961
Halifax
We've only installed 2 of these new heaters, 1 in a Pioneer and 1 in a Talon.
So far we haven't heard of any issues with either.
Mine was faulty from new. Still not working.
From factory there was a 2 wire 12 volt connector that goes to the resistor 6 wire block on front of unit . It was wires backwards. Plugged it I. And resistor burnt . Honda said no parts available and it was manufactured by international climate systems in texts . Called and emailed. No one ever replied . 2 k waisted
  • Wow
Reactions: JenElio
JenElio
JenElio
63,549
597,384
Loxahatchee, florida
I'm of no help on this subject but hopefully someone will chime in sooner then later, good luck 🤞🏼
Also, the fella you quoted is no longer a member so I wouldn't expect a response any time soon.
Welcome to the club from South Florida 👍🏼
Start an intro thread and post some pics of your rig.
Reactions: Remington
104,644
@Techman1961
What @JenElio AKA Jennay just said to the max! Ill just add POIDH!
Where you from, Halifax,
In nova Scotia?
104,644
Try your dealer but good luck at getting Honda parts without having to buy the whole kit. Aint gonna happen!
Start thar Intro thread and provide pics!
Fourm penal code 6969
DRZRon1
DRZRon1
834
2,663
Help me out here - the resistor is just the speed control is my guess - should be able to wire to 12v and fun full speed or search duralast blower motor resistor - u have a pic of this thing ?
HBarlow
HBarlow
1,618
6,009
Daniels, WV
To put this issue in perspective - the heaters and other accessories are not "oem" Honda. Products like this are manufactured by small companies and sold to Honda.
I think Honda provides a warranty for accessories through dealers. I would expect the selling Honda dealer to replace the unit under warranty but if it was not installed by the dealer it may get tricky.
Honda might deny the warranty if it is believed the heater was damaged by the purchaser or installer.
Techman1961
Halifax
Here are pics. It’s made by international climate systems
IMG 8225 IMG 8224
  • Wow
