I replaced my Original belly pan with a 3/8” UHMW three piece that I bought on Ebay for $250 shipped. The hole for the rear differential drain was on the wrong side, bur I corrected that and the rear holes of the center or engine pan were in the wrong place, I just drilled and tapped two new holes in the frame 1/4 20tpi. I also drilled two extra holes near the rear of the front wheel and used carriage bolts into the frame. That was the weak spot in the original. I had to order ten new bolts and washers because the originals from the steel section would not work for the new pan. Those cost me$62 shipped!!! This should be much better protection.
