P1000 New exhaust tip option!!!!!
ehart814
ehart814
1,654
3,643
NWPA
Got mine installed last night (and my mudbusters!!!)
it makes a very slight difference in sound. I don't think anyone is going to complain that it's too loud after installing the new tip. You can hear a little burble once in a while, and I do notice a bit more sound at WFO.
Would I buy it again? yes.
Reactions: Haldog77
Mopower58
Mopower58
CST is the Best!
70,196
644,693
Crystal Springs,Ms.
Here you go. It sounds better in person because you don't hear the engine noise as much. Mic picks up a lot more ambient sound
I would think that the muffler would run a little cooler without as much outlet restriction.
56,731
Especially when it looks like this:
1589474092492
Reactions: Mopower58
GPR1500SC
GPR1500SC
857
2,355
North East MO
  2. Talon X LV
The verdict is they sound about the same.
I believe the Whiskey bent is a teeny tiny little bit quieter maybe? At a idle the new one has a little deeper thump to it? I changed them back a forth and keep coming back to the new one having more of a hollow or deeper sound you wouldn't go wrong with either one.
LIVINTALL
LIVINTALL
54
151
AZ
That's about what I figured. There was a slight difference between no tip and the new tip. The new tip seemed to take a little harshness out of the sound.
russknight
russknight
1,916
7,542
Perry Florida
Be careful removing the three bolts. I wrung one off. Got lucky and was able to drill it out and re-tap it. Didn't like the louder idle. Went back to stock.
ehart814
ehart814
1,654
3,643
NWPA
The more I ride, the more I notice the difference in sound. It does have a little thump to it now at lower rpms and under load. It sounds good. Any louder and I probably wouldn't want it. Mine has also been upgraded to the "Golden Brown Edition". ;)
56,731
Same here. I noticed it the most when engine braking.
TI722
TI722
111
650
IL
  2. Other Brand
I was concerned with the sound, but after install I like it better. I figured if anything I could change it back during hunting season but I really don't think it will matter. Now I just have to wait for the bronze edition to show up 😂😂
1184bcjmill
1184bcjmill
12
34
Lake charles la
Ok was just hoping. I just added 2 3inch bilge fans yesterday. Took it on a little ride but not long enough to tell.
Reactions: Rick53
