New Ford 1/2 ton trucks
nbomar
nbomar
4,416
17,855
Springdale, AR
So basically the Ram had a more luxurious interior, but lacked in most other measures?
I don't know about all the bells and whistles. At some point it's neat but it's not necessary. I have never kept up with the latest tech tho so I probably couldn't benefit anyhow.
Before I bought my 18 platinum f150 I was looking hard at the limited ram. It was nicer inside than the ford. No doubt about it. Ram has the nicest interior...
Tigermark
Tigermark
Outside looking in.
That’s what I took from the article is that the Ram wasn’t the truck to tow with but was the truck if you wanted a mallcrawler.
I just give you the straight facts as I find them. You can interpret them anyway you like. But just FYI, in this article it states tow rating for the Ford is 13200, Ram 12750, a 450 pound difference hardly makes one a mallcrawler.
I still think if you are towing >6-7k on a regular basis the 3/4-1 ton is the way to go. Towing 5500 lbs with my F150 (5.0 and 3.55 with oversized brakes, so in no way set up for towing major loads) is a bear vs towing the same load with dads 1 ton. It's not really the motor, more the way that weight "pushes" the lighter truck. You just feel way more planted in his.
As others have mentioned- mileage is comparable with a comparable load. Mileage unloaded may add up if you drive a lot tho, so that concern is understandable.
Frankly with the same 10 ply Cooper AT3 XLT on both trucks, the ride isn't all that different unloaded either IMO...
Max for most SRW is still around 15k the MaxTow is 13k, the diesel would be much better but long term maintenance and repairs will be more. The F350 is 3300lbs heavier.
Looking I’m shocked that the F-150 is 800lbs lighter than our 2015 explorer...probably explains the 23mpg hwy vs the 19mpg the explorer is rated for.
Yeah but what fun would this thread be if we didn’t prod each other.
nbomar
nbomar
4,416
17,855
Springdale, AR
My brother towed the same 5000(ish) lb boat through the ozarks with my grandfather hemi 4x4 ram quad cab and a first gen ecoboost and he said it wasn’t even close to the same. He thought the hemi was going to blow the motor going up the hills and it was at rev limiter. The ecoboost rarely shifted down... real world comparison with the same driver and same thing being towed. I’m just the messenger though... maybe he will chime in. He’s on this forum.
Tigermark
Tigermark
Outside looking in.
I’ve driven both 1/2 tons Ford and Ram, we had new Fords at Walmart before I left, EB and 5.0 liter. We towed a variety of trailers with different weights with them, and I towed a 31 ft travel trailer that weighed around 7200lbs loaded and towed a variety of other trailers with my Ram. They all handled the various loads pretty well. With that said, everyone has a different perspective and opinion on what that actually means.
I had absolutely no issues towing that load with the Ram. And I averaged 11 mpg, not bad for a lifted truck with large tires. And just FYI, that’s without a tuner or any other mods.
096F861B 5605 4336 B48A 3735DDF03A19 0B8B1167 CE18 494A AB7A E2F839424BE0 4A51C84D 1989 44B1 91CA 1E32C9FF7BC7 660E2A75 A0ED 4FF3 AB6B 2AF9BE2D9EB0 3A5E9E95 DC46 45D0 905E 37022FE60AC1 3D7F66F0 6D11 4CEC 9568 38651E34FCD2 051D0F1E 8CA5 429B B93F 18D9734147E1 C8D487CB C06F 4A97 93A7 C3EA31542895 10081043 3F3E 4A0E A370 D1ADFAD69C58 EDE221C2 EEDC 41FB A067 22F3E46B1E58 E957A510 6677 472D 96FF 502B31C2D182 F04C4E7E 0182 4F65 935B 46609122E80A 8A23D6B7 F9F4 466A A554 0C0EAF3E3D53 39198BC4 B853 4579 B474 90EBCE416A0A D141E99A 32B0 45E0 BB23 CF2EFAB2ED4C DE236BA2 9D4A 491D 9D14 BA4193515C4F E2BC024E 2655 4313 BE92 E59562B03B21 7B16B725 0A82 4977 B0DA 26ABDC610752 B12720C8 BC8B 4609 8A55 950ACDA26CEB 31653FF7 068A 4B53 981A 496ED0FAF751 29E19A94 C2D5 4D03 A6D1 E634CF3C50F8 C9BF594A 303C 48A7 97DD AB90047FC108 23CA6F64 D33E 4EC4 A1F1 83F9A6416C32 624F0B56 6507 455A 9279 4BB67717F038 B41BDF02 036F 42F5 8A76 4673EC06F3B3 1FF2FF48 3D79 4AA7 81DB 09BCE1651524 6B457160 DAA8 4904 9AE3 DE752C1A3831 F3EE440A CCB8 424C A75A 6BA577E5EECB D7715829 B638 4FAD B2C0 BEDB7D8AE436 73F9824D B3CD 42BC A8F1 8C333B5B7C5E 56B3F987 57E5 4999 8F6D 11A98DCE0AC9
Just to rile the Chevy guys up...
Tigermark
Tigermark
Outside looking in.
Tigermark
Tigermark
Outside looking in.
Arguing over 1500 trucks towing is comparable to arguing over arena league football. When you guys get to the big leagues and quit pussyfooting around. Start a thread! Lol
There scared of the power the Cummins engine has. Might not be able to handle it and don’t want to be embarrassed ;)
