As the name implies lol.
So I've got 80k on my 2014 F150 5.0 and she's to that point where I either need to:
1. Sell while shes still worth 20k+ and get something else or
2. Drive her til she blows.
As I mentioned in the other thread: held off on an EcoBoost because of concerns for the turbos/realability and cost to fix.
Sounds like everyone loves the power, so a few more questions about some of these newer half ton fords @joeymt33 and @nbomar and @whoeverelsehasone
1. What did you spend on your tune? Sent it out somewhere or just buy a plug in unit?
2. What additional maintenance does a turbo need? @CumminsPusher you mentioned treating them right at on/off...can you explain?
3. You guys that have the new aluminum body....thoughts? I had an 04 expedition in college and the tailgate and hood where aluminum- bubbly as all get out when it was 8-10 years old. Honestly this has been the biggest thing stopping me from dumping my truck and trading up- the aluminum body scares me.
If these trucks aren't going to have the problem-why? Is there a new coating or finishing process out there I'm not aware of?
1: use 5 Star tuning and what ever device they recommend. Don’t use the high HP tunes when towing. Just use a standard to tune or stock calibration when towing.
2: don’t start and go immediately. Let the oil flow flow for a minute. Same thing when stopping, let it cool before shutting down hot if you were just running it hard.
3: I’ve not had problems with the aluminum. Even when Ford started using the aluminum hoods back in 04 we still didn’t have any problems. Maybe it’s because of the different environment in the south?
I change my oil every 7000 miles and I would do that sooner if I had more city traffic. I’ll let it go that long because I’m on the highway so much. Sometimes I may change it sooner if I have been towing more than usual.
The other thing I recommend is getting a cooler thermostat as the eco boost runs at about 210° and it doesn’t take much of a load or hill to get over 230°. I’m not real comfortable with that so I put in a 170° thermostat a while back and I love it.
I bought an aftermarket spring for the back to increase the spring rate and I use 10 ply tires and this thing hauls and tows very good but it does ride ruffer unloaded and that’s not something I would recommend unless you were always carrying a load.
I havent changed the intake or the exhaust and I still use the stock air filter and everything else.
