P500 New Gel filled Battery for $50
L
Lburou
55
147
Dallas/Fort Worth area, USA
Replacing bad OEM battery with THIS Absorbed Glass Mat, Gel filled battery...Any thoughts?
61yAXCTSSOL AC SL1000
The Amazon Ad said:
Product Description:
YTX14-BS iGel Chrome Pro series batteries are injected with Gel electrolytes and include advanced features such as a digital display and built-in intelligent chip. The display reads the voltage of the battery and alternator while an alarm warns you if there is low capacity/voltage or abnormalities. The iGel series automatically records the working date when your battery is installed and has a longer cycle service life than SLA batteries. Elements like the tough bridge welding, which helps to absorb vibrations, make this battery the premier choice of Power Sport adventurers.
Fakespot rating is four stars.
sarc201
sarc201
15
5
Dayton, Ohio
I have bought batteries before from Chrome. Always had good luck with them for motorcycle and ATV. This battery sounds good. Reviews are kinda all over the place, but the price is right!
Reactions: Lburou
L
Lburou
55
147
Thank you for this report...the description seemed too good to be true. :cool:
NTCPrezJB
NTCPrezJB
Retiring Member
112,670
974,985
Hidden
I’ve got a similar if not the same battery in my Ninja. It sits a lot. I’ve not used a battery tender either. It's only been in a couple of years, but so far it has started every time. The voltage display on it is kind of a cool novelty thing too. It helped me figure out that my aftermarket horn had a surprisingly high power draw.
Reactions: Lburou
