P500 New tailgate
JCart
JCart
895
2,020
Kamloops, BC Canada.
Hey Fellas,
Been wanting to do this for a while and finally got it done. 1.5” steel tube frame, 2” subframe slides into twin receivers (welded) onto Class V hitch. Class V is rated at 1600 lbs downforce and 16,0000 lbs tow capacity. Top is 3/16” aluminum, tie downs are track type mounted on sides of frame. 64.5” wide 34” out the back of box. Will be way stronger than stock tailgate even with solid tailgate straps.
1582342479356
9E6CDB87 E775 4890 B466 D0A15D14BBF3
1582343359901
JCart
JCart
895
2,020
Thanks Fellas,
Plan is to get it loaded today for initial run. Hahaaa Mudder, yes those reflective stripes are next! Have to wait till warmer weather to undercoat the frame. Will try to find 1.5” wide stripes as 2” are to wide. As it sticks out only 34” not gonna bother with extra tail lights the notion was to keep it simple, strong and relatively light.
As a suggestion for anyone else, please consider what you are towing.... the 2” subframe on mine will limit extreme angle trailer tongue movements which I clearly forgot (to consider) when having the shop I used design and weld. I just had a memory lapse, good news is the combo pintle hitch 2 5/16s ball sticks out a fair ways.
To attach the aluminum plate I used Rivnuts at each corner (3/8” stainless bolts) with aluminum oversized (head) pop rivets elsewhere. I’ll do some pix once loaded and test run.
Cheers,
j
JCart
JCart
895
2,020
Loaded P5 up no worries at all, even with plough on.😁
Kinda bummin as I still have lotsa salt on roads and it’s too cool to undercoat it. My Darlin draws the line at painting in the basement... heh heh. So for now will stick on the Conspicuity Tape and will paint/undercoat in a couple months. The patina colour matches the Tan colour on the truck so doesn’t looks bad and I’ve a wet media blaster when it warm out. Few more images.
703AF610 C31B 4D01 AB19 6A934B3610A3
A9AC3BD4 3DBE 4B60 BC49 55D4EA1EBC84
1FECCDC5 6D24 4AB9 95BE B463D6CA0E96
Mudder
Mudder
NTC Ambassador of Walls
11,602
87,332
If using ramps, are you considering some type of pins or something to keep the ramps from moving or kicking out?
JCart
JCart
895
2,020
Mudder, I do use folding aluminum ramps, the ones that fold longitudinally. I use ratchet straps on each ramp to secure, it’s quick easy and works. My understanding is that 80% of UTV/ATV incidents happen loading and unloading, in the work place. Probably higher out in the wild where stats aren’t kept, so yes I always use tie downs to secure ramps...always. When I put the summer 37” tires on the old truck, backing up the ramps can feel, well... Let’s just say you don’t wanna mess up.
Mudder
Mudder
11,602
87,332
Good to hear, don’t want any forum members to be Youtube fail fodder. LOL. PS, liking the Avatar pic.
Splorin
305
863
Maine
Nice work. Your 'salt' can't be that bad, that beauty of a truck vanished here 10 years ago.☹
Reactions: trigger and JCart
JCart
JCart
895
2,020
Thanks Splorin, it is a bit of a pet work truck/pavement queen so it gets hot water pressure washed lots winter and summer. I’m guessing salt rates our West here are not as bad as back East, they try to make up for that by putting material through a 1” screen prior to mixing with the salt and spreading on our highways out here... Just the same, already turning patina brown as we speak...
Reactions: Splorin
Hey Fellas,
View attachment 185830View attachment 185831
Nice work Jcart....👍
Reactions: JCart
