L
Lilred02
92
260
Debary Fl
Got my shifter plate and it is getting powder coated Saturday. While im in there is there a certain way or video for me to watch to adjust my linkage?
Reactions: Isaiah
highpocket74
highpocket74
1,840
5,875
Kinder, Louisiana
www.10-80dirtsports.com
I haven’t seen a video or made one myself but it’s a fairly simple process of centering the lever cable play on the neutral notch. It takes a little while to adjust exactly centered but it’s very much worth it.
I found the shop instructions online and it’s only one page!
Reactions: Isaiah
L
Lilred02
92
260
Debary Fl
Ok if you can remember it that would be awesome and you might want to put it in the first post to help your next customer out. My plate should be powdercoated tomorrow and I will post some install pics
Reactions: Isaiah
highpocket74
highpocket74
1,840
5,875
Kinder, Louisiana
Found a print I’d made. I added to first post as you mentioned and will add below
994AD022 CB07 40E9 B01B B7C60854F384
496blazer
15
20
San Martin,Ca
I received my new replacement shifter plate very quick after placing the order. It took about 20 minutes to remove the console cover, install the new plate, and properly adjust the shift cable. I have to say I'm very happy with how it shifts now! huge improvement. I used to avoid using low gear before since it was such a pain to get it to engage. Yesterday during the ride I found myself using low a lot more. Well worth the time and effort to install the new plate. Money well spent!
  • Love
Reactions: Montecresto
highpocket74
highpocket74
1,840
5,875
Kinder, Louisiana
What do you guys think about adding a chamfered edge on colored plates to show aluminum? It kinda looks like a pin striped edge.
This is how my mind works quite often. I'll think of things during the night and it keeps me awake. It's like a switch I can't turn off. So this morning I was up at 4:30, in the shop trying this chamfer idea with my router, before leaving for my day job.
A8C5C21A 19C2 4952 AECA 2FACDB524A78
5,031
22,489
I really like the chamfered edge.
This is the Shock Therapy limit strap clamp -
1620225060248
highpocket74
highpocket74
1,840
5,875
Kinder, Louisiana
Made a couple of these this evening and they turned out awesome! The beveled edge gives it a sharp look. Kinda reminds me of the diamond cut cooling fin edges on Harley’s blacked out engines. I have a lot of black shifter plates so I’ll make some more if these catch on. May add some colored ones too. These black ones are listed on my website as optional colors for the shifter plate.
3432B9B2 9F62 40A4 8417 BFD30D724449
highpocket74
highpocket74
1,840
5,875
Kinder, Louisiana
Spent most of Mother's Day evening in the shop working on these:
849C387D 3BF1 4EA1 B923 F4365A0536EA
Added the beveled edges to black and colors. Not much contrast with silver but I can make one if someone asks. From now on all will be sold like this for 2 reasons; they look great and this will prevent eventual uneven coating wear by the shift lever friction. No change in price.
Reactions: Sheetmetalfab
highpocket74
highpocket74
1,840
5,875
Kinder, Louisiana
Update 5-12-21: The blue shifter plate has been claimed.
Update 5-17-21: The red shifter plate has been claimed.
For the fine folks here I’d like to offer a special deal on 2 less than perfect shifter plates I have. The top sides are visually perfect but the bottom sides are slightly less than perfect and I won’t sell them full price like this. Once installed you’ll see no difference but I believe when a customer gets an item in their hands it should be perfect in all ways even if defects will not be seen after installation.
So the deal goes to the first person to send PayPal info to me via a conversation through this forum. $30 each and shipped for free.
Top side:
E8A4B38F 5524 4A88 8D11 33BBC78470F1
Bottom side:
Red has a few gashes from material handling equipment. Blue beveled edge is not uniform and wider than usual because the edging bit worked loose.
1B412549 E556 4B12 9AEF 9F72858982A1
Great, now I need to do a third upgrade to get the orange chamfered one.....🙄
Maybe I should just wait until you’re finished improving these things.....🤔
Reactions: Remington
sandbaja
sandbaja
130
421
San Diego, CA
  1. Talon R LV
  2. Talon X4 LV
Top side:
Bottom side:
I'll take the red one if you still have it. Edges still chamfered?
Reactions: Isaiah
