P700 New tires with commander shocks
searlest
7
indiana
Hello First I would like to say thanks to all the contributors !!!!
I have been upgrading my pioneer 700 and am adding the Commander Shock upgrade.
I have been reading thru the post and have some questions
My riding is 70% road and 30% around the farm no heavy mudding or hardcore off roading.
I am looking at the below
Kanati Mongrel
Super swamper
I plan to run the same width tire all the way around?
1) If I run the same width all the way around what spacers will I need to make the machine track properly ?
2) do you recommend 14" or 15" rims?
3) Some are saying that 28s will rub even with the commander upgrade ? Is anyone with the commander upgrade and 28 " tires without rubbing ?
4) If not a violation of forum rules can you give recommendation on where the best place to get a great deal on a set of tires and rims ?
swsebek
swsebek
2,854
5,829
pa
Same all the way around isPROBABLY best for you
With the road riding.27s are your best size choice. You can rotate tires that way. Rocky Mountain Atv is best rim and tire source and they set you up good. Once you make your rim and tire choice please post and we will help you out or tell you not too.im not sure the super swampers are for you though.
Others will chime in soon. It's the weekend
I recommend 14s unless you are going pimplook:rolleyes:
swsebek
swsebek
2,854
5,829
pa
I do not believe you will need spacers because tracking does not seem to be and Issue that I have heard...I run 28s myself and they are a pinch too big in stock setup.I run big horns 2.0 6PLY.They are no good for road riding.You will get a much better answer from the others who have gone your rt. and tried the tires and setup.Also go to 700 section wheels and tires.
searlest
7
indiana
Spacers...I would prefer that the wheels "stick out" Evenly just for looks .
So what size spacer will I need
where will be installed ? Front or back ?
Below is what I have found so far ?
  • Imagesashxi4WD SSR07R
    27x9.50R14LT, SSR Radial
    Part #SSTSSR-02R
    Free Shipping on Select Styles and Sets of 4 Super Swamper Tires
    You Save 11%
    $655.96
    - $74.00
    $581.96
    Gbc 16 tir kan mon 10
    GBC Kanati Mongrel 10-Ply Radial Tire 27x9-14
$515.00
4/110 Douglas Crusader Wheel 14x7 4.0 + 3.0 Matte Black
SundayRdr
SundayRdr
575
1,179
McMinville Tn
I went with commander shocks and Maxxis Carnivores 28x10x14 all the way around. I'm very pleased with them so far. We do quiet a bit of road riding during the summer months playing in creeks. My 28's will rub with compression around 3/4 of a turn. I have the commander shocks and changed to the 3rd preload setting up front which helped with the rubbing. Quiet a few people are running the mongrel tires so hopefully some will chime in. I would pay attention to the weight of the tire itself. I changed tires and can achieve top speed faster and maintain it better too with lighter tires.
Reactions: swsebek
swsebek
swsebek
2,854
5,829
pa
I really like your rims you picked out, but if you ride in much snow those 10 plys are not for you....heavy as hell too....as stated above the carnivores are bad ass... 27/10 all around and your set.... I don't run spacers, but I don't think you will need them.
Reactions: SundayRdr
swsebek
swsebek
2,854
5,829
pa
DGRider will have some answers too he's a wise ole owl on the 700s
Gator
Gator
The Most Unknown Member
2,476
10,399
Louisiana
If you are buying rims, why not just buy them with the offset you want, so don't need the spacers?
I have 14" rims all the way around and I'm happy with them. Some say that smaller rims and more sidewall provides a smoother ride.
I am running 28" Swamp Lites on 14" rims. I have commander shocks but I also have arched A-arms. But no rubbing.
Where to buy, might depend on which tire you ultimately select.
