highpocket74
Mines doing it as well cant figure out where its comming fromNew 19 model Talon X with about 50 miles on it. I noticed a squeaking noise coming from passenger side rear when running very slowly. Sounds like a rubber squeaking sound on something rotating. It's not the brakes. Anyone run into this yet?
thank you ill have to take it see if thats itI've had 3 Talons making a squealing noise at slow speed or constantly while moving.
All three have been fixed by lubricating or replacing the pinion seal in the rear diff. For whatever reason, they arent greased enough from the factory and rub on the splined collar.
What did you end up doing? Shoot some line in it or pull it and grease it. Mine started doing it yesterday. Just under 100miHello all. I just bought a used 21 Talon X last week with 26 miles. Went out yesterday and put about 40 miles on it. I'm getting the noise from the differential area that does sound like it's coming from the pinion seal area under that metal flange. Can anyone help me with how you lubed the pinion seal and what you used? I would think it's something more in depth than spraying penetrant between the metal flange and the diff but maybe I'm overthinking this. I'd appreciate any advice... Thanks in advance.
Don't expect a reply from this user, he had 1 post and was last active almost 2 years agoWhat did you end up doing? Shoot some line in it or pull it and grease it. Mine started doing it yesterday. Just under 100mi
There is a guy on you tube that addresses the problem,What did you end up doing? Shoot some line in it or pull it and grease it. Mine started doing it yesterday. Just under 100mi
