I’m having issues with starting thinking it’s a timing problem need some clarification…
When I go to start my 1000-5 “cold” it will not fire at all. If I take the air cleaner off it starts if you give it some gas but won’t idle. When you put air cleaner back on it will start but then die as soon as you take your foot off the gas. Once it’s warm it will idle but the idle drops then picks back up. It also backfire sometimes out of intake when trying to start it.Someone has repaired the injector wires already. Let me know if more info is needed.
