Talon Noise while under load
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Noticed this weekend when on the road I have a “chatter” or rattle noise that seems to be coming from between the seats. Only happens when under load (going up a hill or stepping harder on the gas) and can only hear it when on the road. It stops when you let off the gas or when it’s changing gears. Worse at higher speeds. RPM doesn’t make a difference. Any thoughts? Pioneer didn’t do this that I recall.
Reactions: BWAF
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
stupid question, but are your door nets still on? mine rattled like crazy. I know you said noise is coming from the tunnel, just a shot in the dark.
no nets. Mine did rattle too. This is definitely engine/ transmission/ clutch, driveline related.
dpnorth
dpnorth
North adventures south
159
408
Crawfordville FL
www.youtube.com
  2. Other Brand
  3. Talon X
Man... sorry dude, that sucks. Ive only got 10 miles on mine, not enough experience to help ya. I hope you still have a warranty. Good luck with it!
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Have only had it about a month. If i was never on pavement im not sure i would notice it.
PaulF
PaulF
1,462
4,814
1500 miles here and I've had mine on pavement many times, everything from slow up to 65 MPH for miles, smooth as silk as far as I can tell but I only have a half windshield. No vibrations, rattles, chatter but those tires are NOISY on pavement.
I do have the occasional rattle on rough terrain but that is to be expected and I try to chase those down and fix them.
Obvious question...
You wouldn't by chance have it in 4WD do you? That will most certainly cause additional "noises".
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Obvious question...
Not in 4wd, I do have a front and rear windshield so might be quieter than normal because of that.
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
added video to first post
hondabob
1,259
4,988
Prescott Valley, AZ
Its best to compare it with another one. They do make a lot of noise especially if you have a windshield and don't wear a helmet.
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
I have front and rear windshield. And only wear half helmet so my ears Aernt covered. That may contribute to it. I’m gonna take it to the dealer to compare in person. But from watching a ton of videos of people riding I can’t hear it on anyone else’s.
Rambo
Rambo
339
822
Southern Indiana
Sounds like some of the chatter I experienced in my pioneer 1000. I have a Talon now but don't have much time behind the wheel....
On my pioneer I only noticed that chatter when I was on the road, ended up putting a little Lucas oil stabilizer into the sub transmission it helped quite it down some.
I'm sure you already checked but if not look at your oil level in the sub tranny, mine was a little low when I picked it up.
Reactions: Dragon21
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
yea its the first thing i checked when i got it (not because the noise but because ive seen some come without it). Ive checked it since then and is fine. If the dealer says they cant figure anything out ill try some lucas in it
DAJO
182
125
Indiana, Arizona
I am sorry Dragon21 but I don't hear anything unusual in the video. I like to hear and feel the transmission shifting of the Talon under heavy exceleration. We do wear earplugs all the time. With ear plugs I can separate some noises that otherwise would just be loud noise. We wear ear plugs so that we do not have to get hearing aids like a lot of our generation. But it is your hearing and everyone is free to do what they want.
Reactions: CID
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
When it gets to 30mph and up can you here a ratlle/ chatter noise that continues until i let off the gas. The gear change is sometime completely different. Actually, as its changing gears the chatter stops.
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Dealer called me today and they believe it’s the front driveshaft. They removed it and it stopped making the noise. Parts are ordered so will know better when it gets back togather
shs456
turtlecreek nb canada
mine is doing the same thing you were describing,loud chatter under acceleration,in 2wd...i'm going to check my d/s tomorrow...
RedRider059
RedRider059
Pa
Good evening everyone. I'm new to the group. I'm experiencing this same issue with a 2020 Talon 1000r I never heard or maybe noticed this chatter, until I just installed new tires. I just took it out today and really noticed the noise. I'm glad to hear its just a driveshaft issue. I'll remove mine to make sure that's my issue before ordering. I have 940 miles on mine is there anything else everyone is seeing as a warning for other issues?
Moto4
46
51
Vermont
My 2019 Talon-X Turbo has more of a rattle that seems to be coming from behind the passenger seat so I think it's a different issue. It's almost like an exhaust shield rattle. It's most noticeable when slowly climbing a hill though it also does it some during normal acceleration on level ground. I've checked the Turbo support bracket but that is tight. I've tried putting clamps around the shields to prevent rattling but it didn't make any difference. Has anyone else have this issue?
Sawpilot
Sawpilot
57
151
West Virginia
barnwoodbuilds.com
My R is chattering bad thought it was valves or trans BUT thinks to this thread it is for a fact my driveshaft, I took the hood off and reached down and the driveshaft is real loose.
  • Wow
Reactions: Montecresto
